I am a beginner with openhab and have a problem with my rule. Maybe there is somebody who can help me. I want to have a Reminder Rule that reminds me via Notification when my windows are still open for 10 minutes.
But i get the following Error Message in log:
ERROR] [.o.m.r.i.engine.ExecuteRuleJob] - Error during the execution of rule Reminder Window Livingroom
java.lang.IllegalStateException: Could not invoke method: org.openhab.core.persistence.extensions.PersistenceExtensions.changedSince(org.openhab.core.items.Item,org.joda.time.base.AbstractInstant,java.lang.String) on instance: null
my rules:
rule "Reminder Window Child"
Time cron "0 0/10 * * * ?"
Window_Child.state == OPEN && Window_Child.changedSince(now.minusMinutes(10))[|
sendBroadcastNotification(âThe Window is still openâ)
rule "Reminder Window Livingroom"
Window_Livingroom.state == OPEN && Window_Livingroom.changedSince(now.minusMinutes(10))[|
my items:
Group:Contact:OR(OPEN, CLOSED) gContacts âWindow_Contactsâ (All)
First, you should to put your THEN logic in an IF -block as below.
Second, âchangedSinceâ requires that you have a persistence configuration setup (rrd4j or the like) with an rrd4j.persist configuration file which has a strategy encompassing the Window_Child item specifically, or by a group or *. (As have the matching add-on for that particular persistence.). Based on the error message, I suspect you have a missing or erroneous xxxx.persist configuration file.
if ( (Window_Child.state == OPEN) && (Window_Child.changedSince(now.minusMinutes(10) ) )
sendBroadcastNotification("The Window is still open")
I would suggest using a timer for this sort of thing. Create a rule which is triggered whenever the window contact changes state. If the window opens, start a timer which fires after 10 mins and sends your notification.
At the start of the rule, regardless of whether the window state has changed to open or closed, cancel the timer.
So the logic is, anything the window changes state cancel any running timer. Then if the window has been opened restart the timer.
Therefore when the window opens the first time there will be no running timer, so nothing to cancel. Then the 10 min timer is started.
If the window is untouched after 10 mind for timer will fire and you will hey your notification.
If the window is closed before the timer fires, the timer will be cancelled.
I use this pattern for a load of rules and it works very well.
rule "Reminder Window"
Item Window_Child changed to OPEN or
Item Window_Livingroom changed to OPEN
if( Window_Child.state == OPEN || Window_Livingroom.state == OPEN)
Window_Timer = createTimer(now.plusMinutes(10)) [|
Yes. I also agree with @ben_jones12 that using a timer is more straightforward than persistence in this situation â I myself use timers for similar use cases.
Here an example of what I am using for my bathroom windows as my family tends to forget closing them.
It sets the max! thermostat down to 5 degrees and starts a timer when opening the window (knx binary input).
Timer gets canceled when the windows gets closed, in addition it sets back the thermostat to automatic mode.
If the windows stays open for a longer period it pushes a message to an MQTT-Broker which in the end causes a message to be pushed to the iPhone via ânodeRedâ using âboxcarâ. In addition it closes the shutter to prevent cooling down the room to much (There is an iron window grate, but for security reasons this might make sense as well).
Still room for improvement, but working so far, maybe something you can use.
rule "EG_Badfenster_vergessen"
Item EG_BAD_WINDOW changed
if (EG_BAD_WINDOW.state==CLOSED) {
sendCommand (MAX_Thermostat_EG_BAD_Mode, "AUTOMATIC" )
if (EG_BAD_WINDOW_Timer!=null) {
EG_BAD_WINDOW_Timer.cancel
EG_BAD_WINDOW_Timer=null
else if (EG_BAD_WINDOW.state==OPEN) {
sendCommand (MAX_Thermostat_EG_BAD_Mode, "MANUAL" )
sendCommand (MAX_Thermostat_EG_BAD, 5.0 )
if (EG_BAD_WINDOW_Timer==null) {
EG_BAD_WINDOW_Timer=createTimer(now.plusMinutes(15)) [|
logDebug("BAD EG" , "Warning fired")
postUpdate( MQTT_WARNING, "Badfenster EG steht seit ueber 15 Minuten offen, bitte schliessen.")
sendCommand (KNX_Shutter_EG_BAD, DOWN )
Put three (3) back quote (```) characters in a row at the start/end of the code snippet, on a line completely to themselves. If thereâs enough code between these block markers, then itâll be scrollable⊠In addition to colorized.
Hey,
bit old thread but fits into the scenario Iâd like to implement:
Send a notification with a list of open windows when leaving the house.
Iâve created an automated group which also containing the ammount of open windows. In case that value is greater 0 Iâd like to send the item.names via messanger.
This is what Iâve done so far:
//We should also send the open windows
val openWindows = agFenster_open.members.filter(s|s.state==OPEN).size
//logInfo("AlarmSystem", "Offene Fenster: " + openWindows)
if(openWindows > 0){
agFenster_offen.members.filter(s|s.state==OPEN).forEach(
msg = msg + ", s"
sendTelegram("gruppe", "Es sind " + openWindows + " Fenster geöffnet\n" + msg)
Any help on creating the proper forEach loop would be appriciated?
And secondly how to add up a list of the open windows as string to send that via messanger?
Thanks much for your help
Initially this was the error:
2017-11-07 07:42:59.475 [ERROR] [.script.engine.ScriptExecutionThread] - Rule âawayâ: The name âsbâ cannot be resolved to an item or type.
Afterwards I added a variable: var String sb = null
but get following error now:
2017-11-07 07:49:29.401 [ERROR] [.script.engine.ScriptExecutionThread] - Rule âawayâ: The name â.append()â cannot be resolved to an item or type.
