Rule simplification and code reuse
I’m a bit confused, because there is a simple solution with only one rule which which will “rule them all”
Setup a Group Item:
Group:Switch gLowBat "all low bat items"
and set all LowBat Items to be member of that group.
Now one Rule:
// imports at the begin of file
import java.util.HashMap
var HashMap<String, String> mapText = newHashMap(
    "MiMagnet_Front_BattLow"     ->    "Front door open/closed sensor",
    "MiMotion_UpStairs_BattLow"  ->    "Upstairs motion sensor",
    "MiTemp_Bedroom_BattLow"     ->    "Bedroom temperature sensor",
) as HashMap
rule "Low battery warning"
    Member of gLowBat changed to ON
    var String Msg = "Low battery warning: " + mapText.get(triggeringItem.name)
    sendNotification("joe@mail.com", Msg, "lowBattery", "Alert") // to myopenhab.org & mobile
    logWarn("lowBattery", Msg)
    say(Msg) // Output to google home speaker
