- Platform information:
- Hardware: Raspberry Pi3 B+, ARM,1Gb Ram, 8Gb Disk
- OS: Raspbian GNU/Linux 8 (jessie)
- Java Runtime Environment: OpenJDK Runtime Environment (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 1.8.0_152-b76)
- openHAB version: openHAB 2.3.0 Release Build
- Issue of the topic: Simple rule seems not to work
- Please post configurations (if applicable):
** Items **
Number:Temperature Netatmo_Cucina_Temperature "Temperature [%.1f %unit%]" <temperature> { channel = "netatmo:NAMain:home:netatmo_inside:Temperature" }
Number:Dimensionless Netatmo_Cucina_Humidity "Humidity [%d %unit%]" <humidity> { channel = "netatmo:NAMain:home:netatmo_inside:Humidity" }
Number:Dimensionless Netatmo_Cucina_Co2 "Co2 [%d %unit%]" <carbondioxide> { channel = "netatmo:NAMain:home:netatmo_inside:Co2" }
** Rule **
rule "AC cucina"
Item Netatmo_Cucina_Temperature changed
if (Netatmo_Cucina_Temperature.state > 27.5) {
publish("prova","prova","cucinatemp")
} else {
publish("prova","prova","cucinatemp_down")
While the items function correctly (as i’m able to display them in a sitemap and are correct), I got an error while saving the rule:
2018-08-19 11:04:52.454 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'AC cucina': Unknown variable or command '>'; line 5, column 7, length 33
I’ve read some docs and example rules and it seems pretty much correct (the syntax, at least). Please disregard the action as it is just a test to be sure that something is triggered (FYI: mqtt is working correctly so, that is not a problem).
Thanks.
Luca
