I´ve implemented a rule, which should enable alert, but in the night between 00:00 and 06:00 only.
Works fine, but alert was also activated at 07:30 and I don´t understand why.
Did I miss something? Kindly advise.
rule "Open door NIGHTalert"
when Item Maindoor_Status changed
var Number hour = now.getHourOfDay
if ((hour >= 00) || (hour <= 06)) {
if (Maindoor_Status.state==OPEN) {
if (Nightalert.state == ON) {
sendCommand(Siren, ON)
timer = createTimer(now.plusSeconds(1)) [|
sendNotification("myemail@email.com", "ALERT!!!")]
Many thanks, guys!
It´s my first “between different times”-rule, so I was not sure about using “||” or “&&”.
BTW:
the following part of the rule is marked as “problematic” in the OpenHab designer with comment "This expression is not allowed in this context, since it doesn´t cause any side effects"
I have made a similar rule using what I learned in this thread. It looks like this:
rule "Rolladen_Terrassentuer_Runter_wenn_Tuer_zugeht"
Item GF_LivingDining_Door changed to CLOSED
if ((hour >= 22) && (hour <= 06)) {
GF_LivingDining_Middle_Shutter.sendCommand(DOWN)
The question is: will that work, since the first time in question is before midnight? Or do I need to use || (or):
if ((hour >= 22) || (hour <= 06))
Background: I have a rule that closes the roller shutter at 22:00, but only if the corresponding doorsensor is not open (so as to not shut anyone out of the house who exited through that door). I want the roller shutter to close when the door is then closed after the regular closing-time.
Thanks.
I think I understand it now: var Number hour = now.getHourOfDay is (as someone more intelligent than me might have seen right away) a variable of the type number, and that number can be anything from 0 to 23. Nothing left of a time, which was confusing me.
