- Platform information:
Hardware: RPI4
OS: Rasbian
Java Runtime Environment:
openjdk version “11.0.9.1” 2020-11-06 LTS
OpenJDK Runtime Environment Zulu11.43+100-CA (build 11.0.9.1+1-LTS)
OpenJDK Client VM Zulu11.43+100-CA (build 11.0.9.1+1-LTS, mixed mode) -
openHAB version: 3.1.0.M3 - Milestone Build (same issue since OH 3.0)
I have a rule with timer. The rule is very basic and have worked fine (OH1 & OH2) until I upgraded to OH3.
The rule is trigger when PIR is detected to turn on a light.
If the PIR is detected and the timer still exist it will just reschedule the timer.
I have put some extra logging in the rule so I can see how much will be executed.
Rule:
rule "Lys bad"
Member of gBadLysPIR changed to ON
if (Alarm_On_Off.state==ON && FerieModus.state == ON){
sendBroadcastNotification("ALARM! PIR 1. etasje!")
sendCommand(LysAlarm, ON)
createTimer(now.plusSeconds(5), [ |
sendCommand(E1_PIR_Bad, OFF)
else
if ((triggeringItemName.toString() == "E1_PIR_Bad")||(now.getHour() <= 10 || now.getHour() >= 19))
logInfo("logg","0")
var int setBad1LysTimer = 5
logInfo("logg","1")
if((now.getHour() <= 6 || now.getHour() >= 23)) {
setBad1LysTimer = 2
logInfo("logg","3")
//logInfo("logg","Timer: "+setBad1LysTimer)
//logInfo("logg","bad1Lys: " + bad1Lys)
if(bad1Lystimer === null|| bad1Lystimer.hasTerminated())
logInfo("logg","4")
sendCommand(E1_Bad_LED, ON)
bad1Lystimer = createTimer(now.plusMinutes(setBad1LysTimer), [ |
sendCommand(E1_Bad_LED, OFF)
sendCommand(E1_Bad_SPEIL, OFF)
logInfo("logg","5")
bad1Lystimer.cancel
logInfo("logg","6")
bad1Lystimer = null
//logInfo("logg","badLysTimer av")
else{
bad1Lystimer.reschedule(now.plusMinutes(setBad1LysTimer))
logInfo("logg","reschedule badLysTimer :" + setBad1LysTimer)
logInfo("logg","7")
sendCommand(E1_PIR, CLOSED)
logInfo("logg","8")
openhab.log
2021-04-13 21:55:54.378 [INFO ] [org.openhab.core.model.script.logg ] - 0
2021-04-13 21:55:54.389 [INFO ] [org.openhab.core.model.script.logg ] - 1
2021-04-13 21:55:54.417 [INFO ] [org.openhab.core.model.script.logg ] - 4
2021-04-13 21:55:57.750 [INFO ] [org.openhab.core.model.script.logg ] - 0
2021-04-13 21:55:57.758 [INFO ] [org.openhab.core.model.script.logg ] - 1
2021-04-13 21:55:57.795 [INFO ] [org.openhab.core.model.script.logg ] - reschedule badLysTimer :5
2021-04-13 21:55:57.803 [INFO ] [org.openhab.core.model.script.logg ] - 7
