gjurriens
(Guido Jurriens)
May 7, 2016, 11:15pm
1
I’m looking for a rule that will turn a switch on if all members of a group are on.
On the other hand, I also need a rule to turn the switch off again if one or more group members are switched off.
Is anyone able to help me out, cause I can’t seem to wrap my head around it and create the right rule.
Thank you very much for your time.
Kind regards,
Guido Jurriens
villaRob
(villaRob)
May 8, 2016, 6:31am
2
Let’s assume you have following items
Group gItemsGroup
Switch Item01 "Switch 01" (gItemsGroup)
Switch Item02 "Switch 02" (gItemsGroup)
Switch Item03 "Switch 03" (gItemsGroup)
Switch Item04 "Switch 04" (gItemsGroup)
Switch Item05 "Switch 05" (gItemsGroup)
Switch Item06 "Switch 06" (gItemsGroup)
Switch ControlItem "[MAP(testgroup.map):%s]"
You can use a rule like this:
import org.openhab.core.library.types.*
import org.openhab.core.library.items.*
import org.openhab.core.types.*
import org.eclipse.xtext.xbase.lib.*
rule "Group Test"
Item gItemsGroup received update
Thread::sleep(500)
var boolean bAllON = true
gItemsGroup?.allMembers.filter(s | s.state!=ON).forEach[i|
//logInfo("GROUP TEST","ITEM =(" + i.name + ") state=(" + i.state.toString + ")")
bAllON = false
if (bAllON) {
ControlItem.sendCommand(ON)
} else {
ControlItem.sendCommand(OFF)
testgroup.map contains
OFF=ONE MEMBER OFF
ON=ALL MEMBERS ON
undefined=???
gjurriens
(Guido Jurriens)
May 8, 2016, 8:52am
3
Thank you for the code.
I can probably rewrite this to my situation
gpbenton
(Graham Benton)
May 9, 2016, 1:38pm
4
If you define your group with the AND function, the value of the Group item will be ON when all the items in the group are on. For example, from my items,
Group:Switch:AND(ON, OFF) FullyAutomatic "Fully Automatic [ (%d) ]" <switch>
Where the items are
Switch AutomaticLights "Lights Controlled Automatically" <switch> (FullyAutomatic)
Switch AutomaticTemperature "Temperature Controlled Automatically" <temperature> (FullyAutomatic)
Which I think is the behaviour you are after, but without any scripting.
gjurriens
(Guido Jurriens)
May 9, 2016, 7:37pm
5
Thank you, that’s an even better solution.
I just tried it and it works great !!!
