Anyone have an idea for a rule which checks if a light is turned on for i.e. > 15 min - and then act if it is ? The action could be turning the light off - or sending a tweet - or something else…
I’d start a timer when the switch is turn on.
When the timer is run for more then xx do your stuff. If the switch is turned off by any other means reset the timer.
For a timer example look herehttps://github.com/openhab/openhab/wiki/Samples-Rules
val Timer lightOn = null
rule "Light turned on"
Item Light changed
if(Light.state == ON) {
if(lightOn == null || lightOn.hasTerminated){
lightOn = createTimer(now.plusMinutes(15), [|
// light was left on too long
lightOn = null
else {
lightOn.reschedule(now.plusMinutes(15))
else {
if(lightOn != null && lightOn.hasTerminated){
lightOn.cancel
lightOn = null
