- Platform information:
- Hardware: raspberry pi
- OS: openhabian
- openHAB version: 3.2.0
- Issue of the topic: Rule triggered unintentionally
I am struggling with creating a rule that appears to be a simple task.
I am using a Fibaro RGBW zwave controller in my hallway light, which is (amongst others) triggered by motion sensors (using BASIC Command 255).
What I’m trying here is to write a rule that is triggered every time the light goes on in order to then set a define brightness (depending on Day/Night).
But there’s some timing issue with my rule. When I turn OFF the light from a higher value (such as 80%), then the light goes out slowly and for some reasing during this period the rule is being triggered again, so the light is effectively on always…
rule "TagNacht dependent dimming of rgbw1"
Item rgbw1_dimmer changed from 0
logDebug("hallway.rules", "TagNacht dependent dimming of rgbw1")
if (rgbw1_dimmer.state == 0) return; // I appear to never enter here
if (TagNacht.state == ON && rgbw1_dimmer.state != 80) rgbw1_dimmer.sendCommand(80)
if (TagNacht.state == OFF && rgbw1_dimmer.state != 15) rgbw1_dimmer.sendCommand(15)
myTimer3 = createTimer (now.plusMinutes(60), [|
rgbw1_dimmer.sendCommand(OFF)
myTimer3 = null
Many thanks for your hints on how to fix this
Regards, Stefan
