If you could post everything in the rules file, not just a single rule, it might be easier to help spot the problem.
Good suggestion. Attached my entire file. There is not a lot there at the moment
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
var Number counter = 1
var Timer timer = null
// Creates an item that stores the last update time of this item
rule "Records last weather update time"
Item Weather_Temperature received update
postUpdate(Weather_LastUpdate, new DateTimeType())
rule "Initialize Location"
System started
DemoLocation.postUpdate(new PointType ("51.44666,-0.85117"))
rule "Set daily max and min temperature"
Item Weather_Temperature changed or
Time cron "0 0 0 * * ?" or
System started
val max = Weather_Temperature.maximumSince(now.withTimeAtStartOfDay)
val min = Weather_Temperature.minimumSince(now.withTimeAtStartOfDay)
if (max !== null && min !== null) {
postUpdate(Weather_Temp_Max, max.state)
postUpdate(Weather_Temp_Min, min.state)
/** shows how to use sensor values from the past */
rule "Persistence Demo"
Time cron "0 * * * * ?"
if(Weather_Temperature.changedSince(now.minusMinutes(1))) {
logInfo("PersistenceDemo", "2 minutes ago, the temperature was " + Weather_Temperature.historicState(now.minusMinutes(2)) + " degrees.")
// This rule will be used to test Scale transformation service
rule "Compute humidex"
Item Weather_Humidity changed
var Number T = Weather_Temperature.state as DecimalType
var Number H = Weather_Humidity.state as DecimalType
var Number x = 7.5 * T/(237.7 + T)
var Number e = 6.112 * Math::pow(10, x.doubleValue) * H/100
var Number humidex = T + (new Double(5) / new Double(9)) * (e - 10)
postUpdate(Weather_Humidex, humidex)
// Switch LGTVStatus "TV State" <switch> - Item Definition (items)
// Number LGTVStatus_Start_Time "TV Start Time [%d]" - Item Definition (items) - Stores Epoch timestamp
// Number LGTVStatus_Stop_Time "TV Stop Time [%d]" - Item Definition (items) - Stores Epoch timestamp
// Number LGTVStatus_Runtime_Minutes "TV Runtime Minutes [%d]" Item Definition (items) - Stores runtime minutes
// rule "TV State"
// when
// Item LGTVStatus changed
// then
// if (LGTVStatus.state == 0) LGTVStatus.postUpdate(OFF)
// if (LGTVStatus.state > 0) LGTVStatus.postUpdate(ON)
// end
var Number Epoch_Time = 0
var Number LGTVStatus_Runtime = 0
rule "Calculate TV Runtime"
then Epoch_Time = now.millis
if (LGTVStatus.state == OFF) LGTVStatus_Stop_Time.postUpdate(Epoch_Time)
if (LGTVStatus.state == ON) LGTVStatus_Start_Time.postUpdate(Epoch_Time)
if ((LGTVStatus_Start_Time.state as DecimalType) > 0 && (LGTVStatus_Stop_Time.state as DecimalType) > 0) {
LGTVStatus_Runtime = ((LGTVStatus_Stop_Time.state as DecimalType) - (LGTVStatus_Start_Time.state as DecimalType)) / 60000
LGTVStatus_Runtime_Minutes.postUpdate(LGTVStatus_Runtime)
logInfo("LGTV", "LGTV Runtime - " + LGTVStatus_Runtime)
Try moving the two global varās to the top of the rules file or place them inside the rule.
This removes the error as long as you donāt need those two varās in the rules above.
if (LGTVStatus.state == OFF) { LGTVStatus_Stop_Time.postUpdate(Epoch_Time) }
if (LGTVStatus.state == ON) { LGTVStatus_Start_Time.postUpdate(Epoch_Time) }
If you need the varās this also removes the error:
System started
DemoLocation.postUpdate(new PointType ("51.24626,-0.75117"))
System started
// rule "TV State"
// when
// then
// end
Thanks @H102 by moving both var`s to the top of the rule this resolve issue with previous warning (missing EOF).
Looking at openhab log file it is showing me some additional validation issues but (INFO) not sure if this is anything to worry about.
2018-12-25 16:10:38.145 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'home.rules', using it anyway:
The use of wildcard imports is deprecated.
2018-12-25 16:10:38.153 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.rules'
2018-12-25 16:18:16.454 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'home.rules', using it anyway:
2018-12-25 16:18:16.584 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.rules'
But I still donāt get any calculations out of this rule.
Is my syntax correct ?
Sitemap
Text item=LGTVStatus_Runtime_Minutes label="Runtime Time [%d]"
Items
Number LGTVStatus_Runtime_Minutes "TV Runtime Minutes"
Should I set anything in rrd4j ? So far I only been adjusting rule file, sitemap & items.
This error is from:
the * in the imports.
Do you need the imports? Most ruleās with OH run without calling for imports. Maybe try the rule without and see if it still runs or try removing the *.
I didnāt really study the rule to much, wrapping paper is everywhere.
If you are trying to compare a current value to an older one then yes you will need to add the items to the persist file.
Example:
Strategies {
// for rrd chart cron strategy every minute
everyMinute : "0 * * * * ?"
// get data reduced for older values to keep database small
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
Items {
LGTVStatus_Runtime_Minutes : strategy = everyUpdate, everyMinute, restoreOnStartup
* : strategy = everyUpdate, everyMinute, restoreOnStartup
You can list all item separate or use the * to add all of them like the second line in items above. See the docās for more details and examples.
Thanks. At the moment my goal is to display total usage time in one day as bare minimum. Later will try to expand it to week/month & year primarily for internal analysis only
I just discovered some errors in log file with regards to rule.
2018-12-25 16:47:44.282 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Calculate TV Runtime': The name 'LGTVStatus_Stop_Time' cannot be resolved to an item or type; line 91, column 31, length 20
2018-12-25 16:48:31.928 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'home.sitemap', using it anyway:
Sitemap should contain either only frames or none at all
2018-12-25 16:48:31.964 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.sitemap'
2018-12-25 16:49:47.439 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Calculate TV Runtime': The name 'LGTVStatus_Start_Time' cannot be resolved to an item or type; line 92, column 30, length 21
2018-12-25 16:51:47.165 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'home.rules', using it anyway:
2018-12-25 16:51:47.268 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.rules'
It doesnāt like āLGTVStatus_Stop_Timeā & āLGTVStatus_Start_Timeā
Those two should be virtual items created by you.
You can forget the persistence for now. Main goal is to get your this rule running. When you do so, you can set up a second rule to reset the counter item at midnight to see daily calculations.
I tried replacing LGTVStatus with another running item at home (light switch) but there is still nothing being populated in this rule. Should I be restarting openhab after updating rule file ?
I seen this topic earlier , probably with slightly easier rule and Vincent solution to increment counter. Will try test it quickly to see if it works.
A restart is not needed.
And yes, you can experiment with something more simple.
Do you know what a virtual item is? You donāt have to replace your tv status item with some other actual item that is linked to a physical switch. Just one ātestā item.
I gather the idea of virtual item. I will try to set up test switch which I could toggle freely and will see if it works. There must be some fundamental mistake in my syntax somewhere.
Hi All,
I had to abandon previous rule as I could not get it to work no matter what I tried .
Found another rule on this forum implementing counter function and after linking to my test device (switchable device for now) it works.
Below you can find the current code which seems to be working for me at the moment.
rule "LGTVStatus counter"
// Every minute, 5 seconds after the minute
Time cron "5 * * ? * * *"
LGTVStatus_Time_Active.postUpdate((LGTVStatus_Time_Active.state as Number) + 1)
if (LGTVStatus_Time_Day.state != NULL) {
LGTVStatus_Time_Day.postUpdate((LGTVStatus_Time_Day.state as Number) + 1)
} else {
LGTVStatus_Time_Active.postUpdate(0)
I will give it a go to see how reliable this code will be.
So as this works for now my next step will be to reset this counter at midnight each day and move accumulated value to another item called LGTVStatus_Time_Day to display total usage value from previous day.
How would I do this ?
I think this should work if I could trigger Midnight_Sync item somehow
rule "Reset today value and sync"
Item Midnight_Sync received command
if (Midnight_Sync) {
LGTVStatus_Time_Day.postUpdate(0)
Also, how to ensure that this data is not lost during day for any reason (openhab restart for example).
Ideally I would like to be able to store this data and then display a device total usage for duration of:
- One day
- A Week
- A Month
- A Year
Regarding the following:
You are actually going to need to setup persistence to achieve your goal.
rule "Reset Counter"
time cron "0 0 0 * * ?" // Fires midnight every day
[do some stuff here]
end```
Regards,
Burzin
Thanks Burzin,
I think I got confused with this code earlier or maybe overcomplicating it.
Just to clarify what I looking to achieve.
When the device is switched ON, LGTVStatus_Time_Active will be showing time in minutes since the unit was switched ON last time.
When the device is being switched OFF , LGTVStatus_Time_Active should clear to 0 and accumulated value should be copied to my daily total run time - LGTVStatus_Time_Day. This value should be available on display throughout the day at any time (till midnight).
At the moment LGTVStatus_Time_Day is showing 0 at all the time.
if (LGTVStatus.state == OFF) { move value from LGTVStatus_Time_Active to LGTVStatus_Time_Day
NB: not exactly sure how to code this above section.
- At midnight LGTVStatus_Time_Day should reset to 0. I think I will need to create another register for that to capture data from previous day - LGTVStatus_Time_YDay (yesterday) ?
This probably would work for last two days but if I would like to gather further information (for the last week or month) it is not very clear for me how to prepare this at the moment. I think this would be very messy if I carry on like this.
Am I trying to understand correctly ?
NB:
I tried to use this rule to reset counter but as soon I add to my rule file it will freeze operation of counter so I had to remove from it for time being.
rule "Reset Daily Counter"
Hi Andy,
My openHAB installation just blew up on me while setting up persistence, so I donāt know how much help I can be, but Iāll try.
Item 1
I think you have this covered.
Items 2 and 3
To me it seems like the best way to accomplish this is to modify the rule in item 1. A line like this may work
if (now.getHourOfDay == 0 && now.getMinuteOfHour == 0) { //ie Midnight
[Do something]
I think you are right that it will get messy, but you may be able to simplify a bit bit by doing additional rollovers in additional rules. If example, imagine an item to hold to week of the year . (item = cal.get(WEEK_OF_YEAR)) then you could act upon a change to that item.
Regards,
Burzin
Need to use capitol letter for time.
Time cron "0 0 0 * * ?" // Fires midnight every day
@H102 - well spotted, capital letter resolved the problem, I forget everything is case sensitive
Graphic illustration what I can see at the moment regarding time ON
Position one āON Timeā is showing minutes elapsed since the unit was initially switched ON. As you can see it was 11 minutes ago. This is linked to LGTVStatus_Time_Active in my counter rule.
Line below āDaily ON Timeā is linked to LGTVStatus_Time_Day and should be showing sum of ON Time values accumulated during a day. So every time TV is switched off I will need to move ON TIME value to DAILY ON TIME somehow. I will see how I can use this syntax provide by @Burzin_Sumariwalla
As per my post above then at midnight DAILY ON TIME should be copied over to another register ,lets called it YDAY ON Time and then counter should reset to 0.
This would give me a partial solution in response to my initial design, still not sure how to capture entire week & month. Perhaps chart could be used.
Setting persistence it will be a challenge for me
LGTVStatus_Time_Day = LGTVStatus_Time_Active.state as Number
Just to update you all on the situation. To my surprise this morning Daily ON Time seems to be working correctly now so its good news. It looks like the problem was with counter reset as I had it set to midnight and it wouldn`t work without this being set to 0 first
Now when the TV is switched ON, the āON Timeā will be showing minutes elapsed since the unit was switched ON. When the device goes OFF āON Timeā counter will reset to 0 and then restarts as soon TV is switched ON again. āDaily ON Timeā will capture a sum of every āON Timeā instances as expected.
Next challenge will be populate this data to show daily/weekly and monthly usage. Perhaps chart is the best way to achieve it?
Evening All,
I have 3 devices which are being monitored at the moment. I used the same rule for all three devices to calculate runtime but weirdly only one rule works well - calculates MyDevice1_Time_Active & MyDevice1_Time_Day properly.
Below is the copy of this rule.
rule "Device 1 counter"
if (MyDevice1.state == ON) {
MyDevice1_Time_Active.postUpdate((MyDevice1_Time_Active.state as Number) + 1)
if (MyDevice1_Time_Day.state != NULL) {
MyDevice1_Time_Day.postUpdate((MyDevice1_Time_Day.state as Number) + 1)
} else {
MyDevice1_Time_Active.postUpdate(0)
MyDevice1_Time_Day.postUpdate(0)
For the remaining two devices I used the same syntax , only changed the device name really.
The rule will calculate LGTVStatus_Time_Active but not LGTVStatus_Time_Day.
Can anyone anyone spot any issues with the second rule as I can`t find anything which could stop rule operation. I did worked for a day (was accumulating total value during day) but then it stopped without any reason and not sure why
} else {
Identical rule names? You can combine all reset rules into one:
Second counter to reset...
Third counter to reset...
