having used openHAB since 0.9 (or has it been 0.6) for years and finally finding about lambdas, here’s my rules file on how to detect which room needs to be vented in order to get humidity out.
You’ll need those items (example for Bad/Bath):
Number T_Bad "Bad [%.1f °C]" (avgThermo) // Current Temperature
Number TSBad "Bad [%.0f °C]" (TS) // Set Temperature
Number H_Bad "Bad [%.0f %%]" (avgHydro) // Humidity
You also need to put items in groups in order for the rule to “find” the items:
Group:Number:MAX avgHydro <humidity>
Group:Number:AVG avgThermo "Ø Innen [%.1f °C]" <temperature>
Group TS
I copied and pasted the whole calculus from someone else. I’m sorry not to be able to mention him/her here for credit
Please see the rule file for item names you need to replace.
import org.eclipse.xtext.xbase.lib.Functions
val Functions$Function2<StringType, Number, DecimalType> vent_room= [ n, crit |
//logDebug("vent_room", n + "")
val t = avgThermo.members.findFirst[name.equals("T_"+n)]
val h = avgHydro.members.findFirst[name.equals("H_"+n)]
val ts = TS.members.findFirst[name.equals("TS"+n)]
val tp = TP.members.findFirst[name.equals("TP"+n)]
if ((t.state == NULL) || (T_Outside.state == NULL) || (h.state == NULL) || (Humidity.state == NULL)) {
logWarn("vent_room", n + " Fehler")
return false
// Variablen
var Number temp_in = t.state as DecimalType //Inner Temperature in Grad Celsius
var Number rel_hum_in = h.state as DecimalType //relative Humidity inside
var Number temp_out = T_Outside.state as DecimalType //Outside Temperature in Grad Celsius
var Number rel_hum_out = Humidity.state as DecimalType //relative Humidity outside
var Number abs_hum_in = 0
var Number abs_hum_out = 0
var Number td_in = 0
var Number td_out = 0
// Konstanten
val gas_const = 8314.3
val mol = 18.016
// var Number ab = 0
var Number sdd = 0
var Number dd = 0
var Number v = 0
var Number a_out = 0
var Number b_out = 0
val a_in=7.5
val b_in=237.3
if (temp_out >= 0) {
a_out=7.5
b_out=237.3
} else {
a_out=7.6
b_out=240.7
// Formeln
// Sättingungsdampfdruck: SDD = 6.1078 * 10^((a*temp)/(b+temp))
// Dampfdruck: DD = rel_hum * 100 / SDD
// Absolute Feuchte: AF = 10^5 * mol / gas_const * DD / (temp + 273.15)
// Taupunkt: TD = b*v/(a-v) mit v = log10(DD / 6.1078)
// absolute Humidity inside, not used
// ab = ((a_in * temp_in) / (b_in + temp_in)).doubleValue()
sdd = 6.1078 * Math::pow(10, ((a_in * temp_in) / (b_in + temp_in)).doubleValue())
dd = rel_hum_in / 100 * sdd
v = Math::log10((dd/6.1078).doubleValue())
td_in = b_in * v / (a_in - v)
//N_TPInnen.postUpdate(td_in)
abs_hum_in = Math::pow(10, 5) * mol / gas_const * dd / (temp_in + 273.15)
//N_TPInnen.postUpdate(abs_hum_in)
// absolute Außenfeuchte
// ab = ((a_out * temp_out) / (b_out + temp_out)).doubleValue()
sdd = 6.1078 * Math::pow(10, ((a_out * temp_out) / (b_out + temp_out)).doubleValue())
dd = rel_hum_out / 100 * sdd
td_out = b_in * v / (a_in - v)
abs_hum_out = Math::pow(10, 5) * mol / gas_const * dd / (temp_out + 273.15)
//logDebug("vent_room", n + " Abs. Luftfeuchte - in: " + abs_hum_in + " g/m3, out: " + abs_hum_out + " g/m3")
logDebug("vent_room", n + " Taupunkt - in: " + td_in + " °C" + ", out: " + td_out + " °C")
// Room not hot enough
// Does not work well
if (
(temp_in >= ts.state) &&
(temp_out <= td_in) &&
((td_in + 2.5) < td_out) &&
(td_in >= (crit + 1))
// VENT
} else {
// DONT VENT
rule "Lüften"
Time cron "0 */5 * * * ?" or
System started
logDebug("vent_room", "Calculating")
// Only when at home
if (Present.state == ON) {
// Syntax is Room, [Temperatur on critical surface]
vent_room.apply("Wohnen", 9)
vent_room.apply("Bad", 8)
vent_room.apply("Eltern", 8)
vent_room.apply("KindN", 12)
vent_room.apply("KindS", 12)
The critical temperature is the lowest known temperature on a surface in the room because of thermal bridges. For example, the last rooms (KindN, KindS) both have bridges because of the shutters not being installed properly
Please let me know how this works for you. Me and my parents made good results venting the humidity out and fighting the mold.
Best,
Sascha
