Rule trigger at specific state?
Hello everyone, How can I make my rule only trigger when my door state was changed to CLOSED when it’s a specific time, this is the code i got right now
rule “nightLock”
Time cron “0/30 * 19-23 1/1 * ? *” or
Time cron “0/30 * 0-7 1/1 * ? *”
ZWaveNode006ID150ZWaveModuleForIDLock150And101_DoorLock.sendCommand(ON)
rule “dayLock”
Time cron “0 0 11 1/1 * ? *”
ZWaveNode006ID150ZWaveModuleForIDLock150And101_DoorLock.sendCommand(OFF)
On the night its draining my battery like crazy. and when the door closes and open this comes in the log file,
2020-05-15 16:43:52.293 [vent.ItemStateChangedEvent] - ZWaveNode006ID150ZWaveModuleForIDLock150And101_DoorState changed from CLOSED to OPEN
2020-05-15 16:43:58.566 [vent.ItemStateChangedEvent] - ZWaveNode006ID150ZWaveModuleForIDLock150And101_DoorState changed from OPEN to CLOSED
Is it possible to make it lock when the door state has changed to CLOSE than rather trying to close it every 30sec?:slight_smile:
Yes. What difficulty are you having with doing that?
rule “nightLock”
if (ZWaveNode006ID150ZWaveModuleForIDLock150And101_DoorState changed to CLOSED)
Tryed this but wont work
Well no, it’s not sensible syntax.
I thought you wanted the rule to run when the door is closed?
rule "nightLock"
   Item ZWaveNode006ID150ZWaveModuleForIDLock150And101_DoorState changed to CLOSED
and then maybe check time of day, like here -
