I have a very simple rule that is triggered based on the “Armed” led of my alarm system as below…
I want it to turn the house ventilation to FULL when we arm the alarm meaning we have left the house.
Problem is that sometimes the young children can arm the alarm by mistake if they play with the remote and so it is quickly disarmed again by an adult…
How could I cater for this in a rule so that the actions in the rule will not run if the LED is set back to it’s previous state within 15 seconds or something like that? At the moment the entire rule fires twice…
I’m thinking of some sort of logic like like comparing the LED’s state with what it was 15 seconds ago and only then if it’s changed run the rule… Could something like that be possible?
Rule "Actions based on DSC Alarm"
Item KEYPAD_ARMED_LED received update
if (KEYPAD_ARMED_LED.state == 1) {
// Turn ventilation fan to HIGH
LNR801a.sendCommand(ON)
LNR801e.sendCommand(OFF)
LNR801h.sendCommand(OFF)
if (KEYPAD_ARMED_LED.state == 0) {
// Turn ventilation fan to LOW
LNR801a.sendCommand(OFF)
LNR801h.sendCommand(ON)
I found this in the rules samples using a “timer” but I suspect that this will still result in the action being run when the adult disarms the alarm again…
import org.openhab.model.script.actions.Timer
var Timer timer
rule "do something if item state is 0 for more than 10 seconds"
Item MyItem changed
if(MyItem.state==0) {
timer = createTimer(now.plusSeconds(10)) [|
// do something!
} else {
if(timer!=null) {
timer.cancel
timer = null
Thanks for the reply!
I think that when the LED status is set back to 0 the rule will do the action because it’s changed to 0 and stays there for long enough for the timer to fire…
If it’s change from 0 to 1 and then back to 0 again within 15 seconds I don’t want anything to happen.
That’s not correct, the example you posted would work as follows:
Somebody arms the alarm by mistake, a timer is started and will execute the actions in its brackets after 15 seconds
Before the 15 seconds are up, somebody disarms the alarm
The rule fires a second time, but this time it won’t create a timer with actions, it will go to the else statement, check if there is a timer set and then cancel it (timer.cancel)
