I want to trigger a rule for every item change. Is this possible?
I tried
when Item * changed
but it is not accepted.
Any idea?
I tried
when Item * changed
Any idea?
Are you sure you want to do that?
For what purpose?
I want to notify to the new MQTT binding the item change status as discussed in topic: https://community.openhab.org/t/new-mqtt-2-4-binding/
So you assume at the moment that all your items are using MQTT. However this will most definitly change! Using a group will help you out anyway.
no, actually my items are zwave devices, but as I want to notify externally I see no other way to do it.
Then your approach is to create a group, with all the items that need to send a notification for the state change, isn’t it?
