It seems to be default. My installation is defaulted to this, too.
rule āsmokeAlertā
Item zwave_device_158e8e1f486_node5_alarm_smoke received update ON
sendSms("+4530220000", āAlarm Brandā)
sendNotification(āalarm@mail.nuā, āsĆ„ er der Alarmā)
use to work for me in oh1, but doesnāt seem to work in oh2
in Association Groups
3: Device Status
it says pendingā¦
i set Secure Inclusion Mode to do not use and reinitialised
I am surely no rule specialist, but Iāve never seen this expression. I know āreceived updateā and I know āchanged from OFF to ONā, but not your version. Maybe youāll try changed off/on?
And pending means, that the new setting hasnāt yet been transmitted to the device. This happens automatically with the next wake up. If you want to transmit it now, you have to wake up the device manually (3x button press)
wake up has been doneā¦ i donāt see any changes or updates form node 5 in my events
2016-12-13 17:45:36.427 [WARN ] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Unknown command class 0x91
2016-12-13 17:45:52.128 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: Retries exceeded at SET_ASSOCIATION
2016-12-13 17:46:05.921 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising Thing Nodeā¦
2016-12-13 17:46:06.462 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising Thing Nodeā¦
well the rule works with the tamper(general alarm).
I just read this threat since Iām also struggling with the fibaro smoke sensor. Just to be sure, I installed today the latest snapshot of openhab2 online distribution 2.0.0.201701091302
Iām not quite sure wether to open another threat or not, but I thinks itās worth first to try it within this one.
Every time the device wakes up and every time i press the button in order to force an update of the temperature for example I get all alarms the sensor is able to send.
This is quite annoying. Iām not quite sure if a real alarm is fired the same way, but at the end currently the alarm channels are triggered with each wake up.
Perhaps I make something wrong, but I have no clue what this might be.
Any hints are very appreciated.
Thanks in advance.
Relevant lines from the trace log:
2017-01-08 14:25:53.355 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 11: Incoming command class ALARM
2017-01-08 14:25:53.359 [TRACE] [ssage.ApplicationCommandMessageClass] - NODE 11: Found Command Class ALARM, passing to handleApplicationCommandRequest
2017-01-08 14:25:53.363 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: Received ALARM command V3
2017-01-08 14:25:53.375 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: Process NOTIFICATION_REPORT V3
2017-01-08 14:25:53.379 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: NOTIFICATION report - 0 = 0, event=254, status=255
2017-01-08 14:25:53.383 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: Alarm Type = BURGLAR (0)
2017-01-08 14:25:53.387 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
2017-01-08 14:25:53.394 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2017-01-08 14:25:53.398 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
2017-01-08 14:25:53.404 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:53.409 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:53.414 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 254, type OnOffType
2017-01-08 14:25:53.419 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Updating channel state zwave:device:876267ab:node11:alarm_tamper to ON [OnOffType]
2017-01-08 14:25:53.427 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:53.433 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:53.438 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:53.445 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Messa
2017-01-08 14:25:52.678 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 11: Incoming command class ALARM
2017-01-08 14:25:52.683 [TRACE] [ssage.ApplicationCommandMessageClass] - NODE 11: Found Command Class ALARM, passing to handleApplicationCommandRequest
2017-01-08 14:25:52.696 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: Received ALARM command V3
2017-01-08 14:25:52.701 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: Process NOTIFICATION_REPORT V3
2017-01-08 14:25:52.706 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: NOTIFICATION report - 0 = 0, event=254, status=255
2017-01-08 14:25:52.710 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: Alarm Type = SMOKE (0)
2017-01-08 14:25:52.715 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
2017-01-08 14:25:52.725 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2017-01-08 14:25:52.729 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
2017-01-08 14:25:52.735 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:52.740 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 254, type OnOffType
2017-01-08 14:25:52.745 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Updating channel state zwave:device:876267ab:node11:alarm_smoke to ON [OnOffType]
2017-01-08 14:25:52.764 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:52.769 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:52.775 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:52.779 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:52.789 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=11, callback=78, payload=0B 05 71 04 00 01 01
2017-01-08 14:25:53.929 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 11: Incoming command class ALARM
2017-01-08 14:25:53.932 [TRACE] [ssage.ApplicationCommandMessageClass] - NODE 11: Found Command Class ALARM, passing to handleApplicationCommandRequest
2017-01-08 14:25:53.933 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: Received ALARM command V3
2017-01-08 14:25:53.945 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: Process NOTIFICATION_REPORT V3
2017-01-08 14:25:53.948 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: NOTIFICATION report - 0 = 0, event=254, status=255
2017-01-08 14:25:53.952 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: Alarm Type = POWER_MANAGEMENT (0)
2017-01-08 14:25:53.956 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
2017-01-08 14:25:53.969 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2017-01-08 14:25:53.973 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
2017-01-08 14:25:53.978 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:53.989 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:53.992 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:53.996 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 254, type OnOffType
2017-01-08 14:25:54.009 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Updating channel state zwave:device:876267ab:node11:alarm_battery to ON [OnOffType]
2017-01-08 14:25:54.015 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:54.019 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:54.818 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 11: Incoming command class ALARM
2017-01-08 14:25:54.821 [TRACE] [ssage.ApplicationCommandMessageClass] - NODE 11: Found Command Class ALARM, passing to handleApplicationCommandRequest
2017-01-08 14:25:54.824 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: Received ALARM command V3
2017-01-08 14:25:54.831 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: Process NOTIFICATION_REPORT V3
2017-01-08 14:25:54.822 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
2017-01-08 14:25:54.845 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT
2017-01-08 14:25:54.849 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Received SOF
2017-01-08 14:25:54.858 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: NOTIFICATION report - 0 = 0, event=1, status=255
2017-01-08 14:25:54.864 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: Alarm Type = SYSTEM (0)
2017-01-08 14:25:54.868 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
2017-01-08 14:25:54.875 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2017-01-08 14:25:54.887 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
2017-01-08 14:25:54.891 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:54.880 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0F 00 04 00 0B 09 71 05 00 00 00 FF 04 FE 00 87
2017-01-08 14:25:54.877 [INFO ] [e.model.script.ZWave Daten empfangen] - 14:25:54 08.01.2017
2017-01-08 14:25:54.905 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 0F 00 04 00 0B 09 71 05 00 00 00 FF 04 FE 00 87
2017-01-08 14:25:54.909 [TRACE] [wave.internal.protocol.SerialMessage] - Calculated checksum = 0x87
2017-01-08 14:25:54.917 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Checksum matched
2017-01-08 14:25:54.907 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:54.921 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:54.924 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:54.928 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 1, type OnOffType
2017-01-08 14:25:54.934 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Message payload = 00 0B 09 71 05 00 00 00 FF 04 FE 00
2017-01-08 14:25:54.937 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
2017-01-08 14:25:54.939 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Updating channel state zwave:device:876267ab:node11:alarm_system to ON [OnOffType]
2017-01-08 14:25:54.948 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT
2017-01-08 14:25:54.952 [INFO ] [e.model.script.ZWave Daten empfangen] - 14:25:54 08.01.2017
2017-01-08 14:25:54.957 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:55.160 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 11: Incoming command class ALARM
2017-01-08 14:25:55.165 [TRACE] [ssage.ApplicationCommandMessageClass] - NODE 11: Found Command Class ALARM, passing to handleApplicationCommandRequest
2017-01-08 14:25:55.169 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: Received ALARM command V3
2017-01-08 14:25:55.174 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: Process NOTIFICATION_REPORT V3
2017-01-08 14:25:55.179 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: NOTIFICATION report - 0 = 0, event=254, status=255
2017-01-08 14:25:55.183 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 11: Alarm Type = HEAT (0)
2017-01-08 14:25:55.188 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
2017-01-08 14:25:55.193 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2017-01-08 14:25:55.197 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
2017-01-08 14:25:55.202 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:55.207 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:55.212 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:55.216 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:55.221 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-08 14:25:55.225 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 254, type OnOffType
2017-01-08 14:25:55.230 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Updating channel state zwave:device:876267ab:node11:alarm_heat to ON [OnOffType]
I think you are not using the latest binding? I see the binding is using the event 254 and I added a check for this last weekend.
Please update to the latest version and see if this works better - if not please post another log and Iāll take a look when I get a chance (might be Friday now though).
Hi Chris, thanks a lot for ypur support. I will do so. I suggest to continue the conversation on the other thread if neccessary, because itās completely relates to the fibaro smoke sensor.
Thanks for now.
Iām strugling with this smoke detector.
The TAMPER and TEMPERATURE is working.
However, SMOKE alarm is not.
I have a gen5 stick so itās + compatible.
Latest snapshot of OH2 and from there I installed the z-wave binding so itās also the latest.
Detector is in only one association group (1 and it is openhab controller).
Switch Fibaro1SmokeDectSmoke "Corridor Smoke Dect [%s]" (ZWave, gSmokeDetector) {channel="zwave:device:e25d115d:node14:alarm_smoke" }
Switch Fibaro1SmokeDectHeat "Corridor Heat Dect [%s]" (ZWave, gSmokeDetector) {channel="zwave:device:e25d115d:node14:alarm_heat" }
Switch Fibaro1SmokeDectTamper "Corridor Smoke Dect Tamper [%s]" (ZWave, gSmokeDetector) {channel="zwave:device:e25d115d:node14:alarm_tamper" }
Number Fibaro1SmokeDectBattery "Corridor Smoke Dect Battery level [%d %%]" (ZWave, gSmokeDetector) {channel="zwave:device:e25d115d:node14:battery-level", mqtt=">[brokerXXX:state:*:${state}]" }
Number Fibaro1SmokeDectTemp "Corridor Smoke Dect Temp [%.1f Ā°C]" (ZWave, gSmokeDetector) {channel="zwave:device:e25d115d:node14:sensor_temperature", mqtt=">[brokerXXX/state:state:*:${state}]" }
When I blow smoke in the detector and it goes off, nothing happens.
But when it goes silent, it sends āOFFā.
Am I missing something really silly in my items file or configuration of the device?
According to logs I can see that it sends 255
@chris, you had one of these detectors, how did you set it up?
13:09:49.067 14
RX REQ ApplicationCommandHandler SENSOR_MULTI_LEVEL_REPORT TEMPERATURE=34
13:09:49.069 14
STATE UPDATE zwave:device:e25d115d:node14:sensor_temperature 25.5 [DecimalType]
13:09:49.582 14
RX REQ ApplicationCommandHandler ALARM_REPORT SMOKE
13:09:49.670 14
RX REQ ApplicationCommandHandler SENSOR_ALARM_REPORT SMOKE=255
13:09:49.711 14
13:09:49.835 14
RX REQ ApplicationCommandHandler BASIC_SET
13:09:49.873 14
13:10:12.252 14
13:10:12.255 14
STATE UPDATE zwave:device:e25d115d:node14:sensor_temperature 26.7 [DecimalType]
13:10:32.367 14
13:10:32.369 14
STATE UPDATE zwave:device:e25d115d:node14:sensor_temperature 27.8 [DecimalType]
13:11:08.978 14
13:11:08.980 14
STATE UPDATE zwave:device:e25d115d:node14:sensor_temperature 28.8 [DecimalType]
13:11:50.309 14
13:11:50.311 14
STATE UPDATE zwave:device:e25d115d:node14:alarm_smoke OFF [OnOffType]
13:11:50.397 14
RX REQ ApplicationCommandHandler SENSOR_ALARM_REPORT SMOKE=0
13:11:50.439 14
13:11:50.563 14
13:11:50.601 14
13:12:48.814 14
13:12:48.817 14
13:15:28.764 14
13:15:28.767 14
STATE UPDATE zwave:device:e25d115d:node14:sensor_temperature 26.8 [DecimalType]
Full log can be found here: https://www.dropbox.com/s/6adodsvs0vg2x94/openhab.log?dl=0
Can you provide the XML file for this device. It looks like itās using a different event than other devices.
