Hi, i want to create an openhab rule with a timer event.
I want to have a button on my visu to start making warmwater with my heatingpump. My time-program for warmwater is one time on noon, rest of the day warm water program is disabled.
But sometimes it would be nice to have warm water by pressing a button. I want to make a rule which enables warmwater on my hatingpump for about 60 minutes and after the time is over or the temperature is reached, the warmwater-settings in the heatingpump should be set to the old variables.
How can i do this? Can someone help me a little bit?
Use a timer. You don’t provide enough detail (Items, variables, etc) so this code is notional.
var Timer hotWaterTimer = null
rule "Manual hot water"
Item ManualHotWaterSwitch received command
// save current states into vals
if(hotWaterTimer == null) {
hotWaterTimer = createTimer(now.plusHours(1), [|
// turn off the hot water
// postUpdates with saved states in the vals saved above
else {
hotWaterTimer.resechedule(now.plusHours(1))
I want to end the warmwater programm after 60 minutes or if the water-temperature reached a temp. But i want to stop warmwater on reaching the temp only when the timer is active.
The automatic warmwater program of the heatingpump should run without any changes through the rule.
