I am trying to add a safety feature to a working tank refill logic.
The system is running w/o fault for a few years now, however, today, a faulty valve (which did not open) presented the scenario that the pump would try to fill the tank, but couldn’t, because the tank level did not increase… hence, if this is not discovered by a human, the pump will run forever, eventually burning out.
My idea is to add a safety check, by checking every three minutes, whether the tank level has increased. If not, kill the whole tank filling process and send an email to that effect.
The rule would trigger on when Item Bore_Pump_Status changed to ON
, set a timer to three minutes to then check if the new Tank_Irrigation_Level
has changed, if not stop the tank fill process, and send email.
var Timer Timer_BorePumpSafety = null
rule "Bore pump safety"
var int tank_level_old = (Tank_Irrigation_Level.state as Number).intValue
Timer_BorePumpSafety = createTimer(now.plusMinutes(3), [|
if ( (Tank_Irrigation_Level.state as Number).intValue - tank_level_old < 1 )
// stop re-fill process logic here
Timer_BorePumpSafety?.cancel()
else
if (Timer_BorePumpSafety !== null)
Timer_BorePumpSafety.reschedule(now.plusMinutes(3))
rule "Bore Pump stopped"
Item Bore_Pump_Status changed to OFF
The ON rule does not work; I get the error “Cannot refer to the non-final variable tank_level_old inside a lambda”.
Any hints appreciated. Maybe I am approaching this the wrong way?
