Hello all,
I’m running openHab2 on a Raspberry Pi 3 and having random problems when openHab starts. I have reduced the rule file to the minimum so, I can focus only in the code that generates the problem. When openHab starts, either at system startup or manually, the most of time, the log file show the following errors:
2017-06-22 19:01:41.457 [WARN ] [me.internal.engine.RuleContextHelper] - Variable 'lock1' on rule file 'default.rules' cannot be initialized with value 'org.eclipse.xtext.xbase.impl.XConstructorCallImplCustom@71019e (invalidFeatureIssueCode: null, validFeature: false, explicitConstructorCall: true, anonymousClassConstructorCall: false)': An error occurred during the script execution: null**
By the way, few times, it works perfectly without any error and, of course, without any change in rule file.
I have observed that the errors refer to variables that depends of imports definition (discrete variables never cause errors). Also, not always all variables cases the problem; some times only one or two.
I’m going really crazy. I have tried to full qualify variables, change the position on the rule file, change the code, etc. without success so, any help will be appreciated.
This is the rule file:
import java.util.ArrayList
import java.util.List
import java.util.concurrent.locks.ReentrantLock
import org.eclipse.smarthome.core.library.types.DecimalType
import org.eclipse.smarthome.model.script.actions.Timer
// calculos presion de la caldera
var boolean msgPresCalderaSent = false
// variables para PIR y Alarma
var Timer pirTimeout = null
// variables para el control de presencia
var boolean alguienEnCasa = false
var Timer presenciaTimeout = null // tiempo de ausencia para considerar que no hay nadie en casa
// Variables disco mode
var Timer discoTimer
var Number flipFlop
// para la gestión de toldos
var Timer toldo1Timer = null
var Timer toldo2Timer = null
var Timer toldo3Timer = null
// calculos de energia
var Number eByHour
var Number eByDay
// variables generales
var String msg
// variables para el subsistema de riego
var boolean cancelRiego = false
var Number zonaActPrev = 0
var Timer riegoTimer = null
var List<String> nombreZonaRiego = new ArrayList<String>()
var List<String> cmdZonaRiego = new ArrayList<String>()
var List<String> topicZonaRiego = new ArrayList<String>()
// Variables Termostato
var List<Number> TZ1TAHistory = new ArrayList<Number>()
var Number TZ1TAaverage
var List<Number> TZ2TAHistory = new ArrayList<Number>()
var Number TZ2TAaverage
var List<Number> TZ3TAHistory = new ArrayList<Number>()
var Number TZ3TAaverage
var List<Number> TZ4TAHistory = new ArrayList<Number>()
var Number TZ4TAaverage
var int TZ1i = 4
//var TAHistory1 = newArrayList(1, 2, 3) //no funciona
var java.util.concurrent.locks.ReentrantLock lock1 = new ReentrantLock()
rule "System startup"
System started
logInfo("STARTUP","Start rule System startup")
// Crea un timer para ejecutar la inicialización de variables despues que la persistencia se
// reestablezca
logInfo("STARTUP","Create timer to init var and arrays")
createTimer(now.plusSeconds(45)) [|
logInfo("STARTUP","Initiating var and arrays")
// carga el array con los nombres de las zonas (nombre de los item del grupo RIEGO_TIEMPO)
RIEGO_TIEMPO.members.forEach[item |
nombreZonaRiego.add(item.name)
// carga el array con el comando para activar y desactivar las zonas
cmdZonaRiego.add("pcfgpio,65,") // Zona 1
cmdZonaRiego.add("pcfgpio,66,") // Zona 2
cmdZonaRiego.add("pcfgpio,67,") // Zona 3
cmdZonaRiego.add("pcfgpio,68,") // Zona 4
cmdZonaRiego.add("pcfgpio,69,") // Zona 5
cmdZonaRiego.add("pcfgpio,70,") // Zona 6
cmdZonaRiego.add("pcfgpio,71,") // Zona 7
cmdZonaRiego.add("pcfgpio,72,") // Zona 8
cmdZonaRiego.add("gpio,14,") // Zona 9
cmdZonaRiego.add("gpio,15,") // Zona 10
cmdZonaRiego.add("gpio,4,") // Zona 11
cmdZonaRiego.add("pcfgpio,65,") // Zona 12
cmdZonaRiego.add("pcfgpio,66,") // Zona 13
cmdZonaRiego.add("pcfgpio,67,") // Zona 14
cmdZonaRiego.add("pcfgpio,68,") // Zona 15
cmdZonaRiego.add("pcfgpio,69,") // Zona 16
cmdZonaRiego.add("pcfgpio,70,") // Zona 17
cmdZonaRiego.add("pcfgpio,71,") // Zona 18
cmdZonaRiego.add("") // Zona 19
cmdZonaRiego.add("") // Zona 20
// carga el array con el mqtt topic para activar y desactivar las zonas
topicZonaRiego.add("/Riego/cmd") // Zona 1
topicZonaRiego.add("/Riego/cmd") // Zona 2
topicZonaRiego.add("/Riego/cmd") // Zona 3
topicZonaRiego.add("/Riego/cmd") // Zona 4
topicZonaRiego.add("/Riego/cmd") // Zona 5
topicZonaRiego.add("/Riego/cmd") // Zona 6
topicZonaRiego.add("/Riego/cmd") // Zona 7
topicZonaRiego.add("/Riego/cmd") // Zona 8
topicZonaRiego.add("/Riego/cmd") // Zona 9
topicZonaRiego.add("/Riego/cmd") // Zona 10
topicZonaRiego.add("/Riego/cmd") // Zona 11
topicZonaRiego.add("/Riego2/cmd") // Zona 12
topicZonaRiego.add("/Riego2/cmd") // Zona 13
topicZonaRiego.add("/Riego2/cmd") // Zona 14
topicZonaRiego.add("/Riego2/cmd") // Zona 15
topicZonaRiego.add("/Riego2/cmd") // Zona 16
topicZonaRiego.add("/Riego2/cmd") // Zona 17
topicZonaRiego.add("/Riego2/cmd") // Zona 18
topicZonaRiego.add("") // Zona 19
topicZonaRiego.add("") // Zona 20
sendCommand(ZONA_ACT, 0)
// Inicializa variales por defecto al arranque
if (RIEGO_HORA.state == NULL)
sendCommand(RIEGO_HORA, 0)
if (RIEGO_MINU.state == NULL)
sendCommand(RIEGO_MINU, 30)
if (RIEGO_SW.state == ON)
// si el riego automatico esta arrancado, el valor presistido (ON) se carga en el item pero
// no dispara la rule asociada. Esto fuerza a que se dispare.
//logInfo("STARUP","RIEGO_SW es ON")
sendCommand(RIEGO_SW, ON)
sendCommand(RIEGO_HORA,RIEGO_HORA.state.toString) //dispara la rule asociado a RIEGO_HORA
sendCommand(RIEGO_MAN, OFF)
logInfo("STARTUP","var and arrays initiated")
logInfo("STARTUP","End of rule System startup")
And this is the log with errors.
2017-06-22 18:18:08.840 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2017-06-22 18:18:08.849 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
2017-06-22 18:18:22.007 [INFO ] [egram.internal.TelegramActionService] - Bot bot1 loaded from config file
2017-06-22 18:18:23.394 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.1.240:8080
2017-06-22 18:18:23.397 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.1.240:8443
2017-06-22 18:18:33.727 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'micasa.items'
2017-06-22 18:18:34.776 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mysql.persist'
2017-06-22 18:18:55.054 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.rules'
2017-06-22 18:18:56.961 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'micasa.sitemap'
2017-06-22 18:18:57.421 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'MiCasa.things'
2017-06-22 18:18:58.902 [INFO ] [b.core.service.AbstractActiveService] - HTTP Refresh Service has been started
2017-06-22 18:18:58.956 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2017-06-22 18:18:58.959 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mibroker'
2017-06-22 18:18:59.575 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-06-22 18:18:59.882 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2017-06-22 18:19:00.091 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-06-22 18:19:00.946 [INFO ] [rvice.dhcp.ReceiveDHCPRequestPackets] - DHCP request packet listener online
2017-06-22 18:19:01.454 [WARN ] [me.internal.engine.RuleContextHelper] - Variable 'nombreZonaRiego' on rule file 'default.rules' cannot be initialized with value 'org.eclipse.xtext.xbase.impl.XConstructorCallImplCustom@13b4e64 (invalidFeatureIssueCode: null, validFeature: false, explicitConstructorCall: true, anonymousClassConstructorCall: false)': An error occurred during the script execution: null
2017-06-22 18:19:01.459 [WARN ] [me.internal.engine.RuleContextHelper] - Variable 'cmdZonaRiego' on rule file 'default.rules' cannot be initialized with value 'org.eclipse.xtext.xbase.impl.XConstructorCallImplCustom@85aedf (invalidFeatureIssueCode: null, validFeature: false, explicitConstructorCall: true, anonymousClassConstructorCall: false)': An error occurred during the script execution: null
2017-06-22 18:19:01.475 [WARN ] [me.internal.engine.RuleContextHelper] - Variable 'topicZonaRiego' on rule file 'default.rules' cannot be initialized with value 'org.eclipse.xtext.xbase.impl.XConstructorCallImplCustom@92e0f2 (invalidFeatureIssueCode: null, validFeature: false, explicitConstructorCall: true, anonymousClassConstructorCall: false)': An error occurred during the script execution: null
2017-06-22 18:19:01.480 [WARN ] [me.internal.engine.RuleContextHelper] - Variable 'TZ1TAHistory' on rule file 'default.rules' cannot be initialized with value 'org.eclipse.xtext.xbase.impl.XConstructorCallImplCustom@608d67 (invalidFeatureIssueCode: null, validFeature: false, explicitConstructorCall: true, anonymousClassConstructorCall: false)': An error occurred during the script execution: null
2017-06-22 18:19:01.490 [WARN ] [me.internal.engine.RuleContextHelper] - Variable 'TZ2TAHistory' on rule file 'default.rules' cannot be initialized with value 'org.eclipse.xtext.xbase.impl.XConstructorCallImplCustom@13a3255 (invalidFeatureIssueCode: null, validFeature: false, explicitConstructorCall: true, anonymousClassConstructorCall: false)': An error occurred during the script execution: null
2017-06-22 18:19:01.538 [WARN ] [me.internal.engine.RuleContextHelper] - Variable 'TZ3TAHistory' on rule file 'default.rules' cannot be initialized with value 'org.eclipse.xtext.xbase.impl.XConstructorCallImplCustom@f0438e (invalidFeatureIssueCode: null, validFeature: false, explicitConstructorCall: true, anonymousClassConstructorCall: false)': An error occurred during the script execution: null
2017-06-22 18:19:01.559 [WARN ] [me.internal.engine.RuleContextHelper] - Variable 'TZ4TAHistory' on rule file 'default.rules' cannot be initialized with value 'org.eclipse.xtext.xbase.impl.XConstructorCallImplCustom@1cda5d1 (invalidFeatureIssueCode: null, validFeature: false, explicitConstructorCall: true, anonymousClassConstructorCall: false)': An error occurred during the script execution: null
2017-06-22 18:19:01.577 [WARN ] [me.internal.engine.RuleContextHelper] - Variable 'lock1' on rule file 'default.rules' cannot be initialized with value 'org.eclipse.xtext.xbase.impl.XConstructorCallImplCustom@10584a2 (invalidFeatureIssueCode: null, validFeature: false, explicitConstructorCall: true, anonymousClassConstructorCall: false)': An error occurred during the script execution: null
2017-06-22 18:19:01.853 [ERROR] [nding.network.service.NetworkService] - Cannot use DHCP listen: iPhonedeSandra: unknown error
2017-06-22 18:19:03.453 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2017-06-22 18:19:03.583 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
And, for those that are think that I’m crazy, here is the most recent log file showing a correct startup:
2017-06-22 19:12:10.169 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2017-06-22 19:12:20.650 [INFO ] [b.core.service.AbstractActiveService] - HTTP Refresh Service has been shut down
2017-06-22 19:12:20.687 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'mibroker'
2017-06-22 19:12:20.869 [INFO ] [assic.internal.servlet.WebAppServlet] - Stopped Classic UI
2017-06-22 19:12:20.929 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Stopped HABmin servlet
2017-06-22 19:12:21.489 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2017-06-22 19:12:21.503 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2017-06-22 19:12:21.517 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
2017-06-22 19:13:36.815 [INFO ] [egram.internal.TelegramActionService] - Bot bot1 loaded from config file
2017-06-22 19:13:38.206 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.1.240:8080
2017-06-22 19:13:38.209 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.1.240:8443
2017-06-22 19:13:47.795 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'micasa.items'
2017-06-22 19:13:48.819 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mysql.persist'
2017-06-22 19:14:08.334 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.rules'
2017-06-22 19:14:09.998 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'micasa.sitemap'
2017-06-22 19:14:10.489 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'MiCasa.things'
2017-06-22 19:14:11.797 [INFO ] [b.core.service.AbstractActiveService] - HTTP Refresh Service has been started
2017-06-22 19:14:11.842 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2017-06-22 19:14:11.844 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mibroker'
2017-06-22 19:14:12.580 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-06-22 19:14:12.725 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2017-06-22 19:14:12.945 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-06-22 19:14:13.716 [INFO ] [rvice.dhcp.ReceiveDHCPRequestPackets] - DHCP request packet listener online
2017-06-22 19:14:14.139 [ERROR] [nding.network.service.NetworkService] - Cannot use DHCP listen: iPhonedeSandra: unknown error
2017-06-22 19:14:15.767 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2017-06-22 19:14:15.907 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-06-22 19:14:30.181 [INFO ] [lipse.smarthome.model.script.STARTUP] - Start rule System startup
2017-06-22 19:14:30.183 [INFO ] [lipse.smarthome.model.script.STARTUP] - Create timer to init var and arrays
2017-06-22 19:14:45.218 [INFO ] [lipse.smarthome.model.script.STARTUP] - End of rule System startup
2017-06-22 19:15:05.393 [INFO ] [lipse.smarthome.model.script.STARTUP] - Start rule System startup
2017-06-22 19:15:05.396 [INFO ] [lipse.smarthome.model.script.STARTUP] - Create timer to init var and arrays
2017-06-22 19:15:05.411 [INFO ] [lipse.smarthome.model.script.STARTUP] - End of rule System startup
2017-06-22 19:15:15.206 [INFO ] [lipse.smarthome.model.script.STARTUP] - Initiating var and arrays
2017-06-22 19:15:15.319 [INFO ] [lipse.smarthome.model.script.STARTUP] - var and arrays initiated
Thanks in advance for any help.
Antonio Castillo
