our christmas lights have various lights via mqtt and mystrom switch.
Sometimes not all lights are switched on. i have no idea what could be the reason
rule:
rule "cmdChristmas Global ChristmasLightsOutdoorOn"
Item cmdChristmas received update "ChristmasLightsOutdoorOn"
if(ChristmasMode.state == ON)
// State Christmas Lights
sendCommand(StateChristmasLights, ON)
// Christbaum Outdoor, Sternen, Terasse
if(MyStrom05_Switch.state != ON) sendCommand(MyStrom05_Switch, ON)
// Gartenhaus
if(OdGh_SteckdoseAussen.state != ON) sendCommand(OdGh_SteckdoseAussen, ON)
// Buxus Haustuer
if(OdGh_SteckdoseHauswand.state != ON) sendCommand(OdGh_SteckdoseHauswand, ON)
// Christbaum Zimmer Samuel
if(MyStrom06_Switch.state != ON) sendCommand(MyStrom06_Switch, ON)
// Stern Zimmer Noah
if(MyStrom03_Switch.state != ON) sendCommand(MyStrom03_Switch, ON)
// Stern Entree
if(MyStrom07_Switch.state != ON) sendCommand(MyStrom07_Switch, ON)
// Stern Büro
if(MyStrom08_Switch.state != ON) sendCommand(MyStrom08_Switch, ON)
// Stern Sofa
if(MyStrom10_Switch.state != ON) sendCommand(MyStrom10_Switch, ON)
sendNotification("keller-marcel@hispeed.ch", "Christmas Outdoor On (" + new DateTimeType().format("%1$tH:%1$tM %1$tA") + ")")
logInfo("rules","Christmas Lights Outdoor On")
items:
Switch StateChristmasLights
Switch OdGh_SteckdoseAussen "Steckdose Gartenhaus Aussen" <switch>
mqtt=" >[mosquitto:Haus/OD/Gartenhaus/cmnd/Sonoff4Ch/POWER3:command:ON:ON],
>[mosquitto:Haus/OD/Gartenhaus/cmnd/Sonoff4Ch/POWER3:command:OFF:OFF],
<[mosquitto:Haus/OD/Gartenhaus/stat/Sonoff4Ch/POWER3:state:default],
<[mosquitto:Haus/OD/Gartenhaus/tele/Sonoff4Ch/LWT:state:MAP(Reachable.map)]"
Switch OdGh_SteckdoseHauswand "Steckdose Hauswand" <switch>
mqtt=" >[mosquitto:Haus/OD/Gartenhaus/cmnd/Sonoff4Ch/POWER4:command:ON:ON],
>[mosquitto:Haus/OD/Gartenhaus/cmnd/Sonoff4Ch/POWER4:command:OFF:OFF],
<[mosquitto:Haus/OD/Gartenhaus/stat/Sonoff4Ch/POWER4:state:default],
Switch MyStrom03_Switch "ZMystrom 03: Switch" <switch> {mystromecopower="03-Mystrom"}
Switch MyStrom05_Switch "ZMystrom 05: Switch" <switch> {mystromecopower="05-Mystrom"}
Switch MyStrom06_Switch "ZMystrom 06: Switch" <switch> {mystromecopower="06-Mystrom"}
Switch MyStrom07_Switch "ZMystrom 07: Switch" <switch> {mystromecopower="07-Mystrom"}
Switch MyStrom08_Switch "ZMystrom 08: Switch" <switch> {mystromecopower="08-Mystrom"}
Switch MyStrom10_Switch "ZMystrom 10: Switch" <switch> {mystromecopower="10-Mystrom"}
Sometimes the MyStrom05_Switch doesn’t turn on, sometimes the OdGh_SteckdoseAussen doesn’t turn on. the other items works normally fine.
i have also 12 blinds controlled via z-wave. with these it can happen that simply one blind does not close. but normally everything works correctly.
in another article i read that logging to myspql has caused a problem. can that be? i have logged various temperature sensors to mysql via persist function.
