Hi, I’m quite new to Openhab and I can’t get my first rules to trigger. Maybe someone can help me.
The first rule should set the Gang_Soll item to 20 by startup but when i reboot the System this Item does not have any Value. The Second Rule should trigger when one of the items change in value via a setpoint in the Sitemap but even if I remove the if comparison it does noch set the HeizungGang Item to ON
I had several Problems. It worked when changing the Gang_Soll.state == NULL. Also I was trying to convert a temperature Value to a Double via as DecimalType , it worked when using as QuantityType.
