Hi all,
I have set up rules that should process trigger events from my hue dimmer switches.
Example from rule 1:
triggers:
- id: "1"
configuration:
thingUID: hue:0820:001788708acd:8
channelUID: hue:0820:001788708acd:8:dimmer_switch_event
type: core.ChannelEventTrigger
When i am trying to test the trigger channel i always get the following error log:
20:22:57.263 [ERROR] [.internal.events.ThreadedEventHandler] - Error on event handling.
at java.lang.String.contains(String.java:2036) ~[?:?]
at org.openhab.core.automation.internal.module.handler.ChannelEventTriggerHandler.apply(ChannelEventTriggerHandler.java:91) ~[?:?]
at org.openhab.core.internal.events.EventHandler.dispatchEvent(EventHandler.java:143) ~[bundleFile:?]
at org.openhab.core.internal.events.EventHandler.handleEvent(EventHandler.java:111) ~[bundleFile:?]
at org.openhab.core.internal.events.EventHandler.handleEvent(EventHandler.java:84) ~[bundleFile:?]
at org.openhab.core.internal.events.ThreadedEventHandler.lambda$0(ThreadedEventHandler.java:67) [bundleFile:?]
20:22:57.276 [INFO ] [org.openhab.rule.dimSwBederoom ] - reason before if clause is: null
20:22:57.283 [INFO ] [org.openhab.rule.dimSwBederoom ] - event in if clause is: hue:0820:001788708acd:8:dimmer_switch_event triggered 2002.0
20:22:57.287 [INFO ] [org.openhab.rule.dimSwBederoom ] - event.event in if clause is: 2002.0
20:22:57.293 [INFO ] [org.openhab.rule.dimSwBederoom ] - reason is: 2002.0
20:22:57.298 [INFO ] [org.openhab.rule.dimSwBederoom ] - DIM UP Button SHORT event
20:22:57.311 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'g_Schlafzimmer_Leuchten_Szene' received command 2
Here is the script code i am using:
var logger = Java.type('org.slf4j.LoggerFactory').getLogger('org.openhab.rule.' + ctx.ruleUID)
var bedroom_Scene = itemRegistry.getItem("g_Schlafzimmer_Leuchten_Szene");
// Proper init to avoid errors when ran without event available
var reason = null
logger.info("reason before if clause is: " + reason)
if(typeof event !== 'undefined' && typeof event.event !== 'undefined'){
logger.info("event in if clause is: " + event)
logger.info("event.event in if clause is: " + event.event)
reason = event.event
logger.info("reason is: " + reason)
switch(reason){
case "2002.0":
logger.info("DIM UP Button SHORT event")
events.sendCommand(bedroom_Scene, 2)
break
case "2003.0":
logger.info("DIM UP Button LONG event")
break
case "3002.0":
logger.info("DIM DOWN Button SHORT event")
events.sendCommand(bedroom_Scene, 1)
break
case "3003.0":
logger.info("DIM DOWN Button LONG event")
break
default:
logger.info("Unknown Switch Event triggered. No action fired!")
As you can see the complete script is working anyway after the error message and commands are executed as wanted.
Did somebody face this NPE yet?
- Platform information:
- Hardware: CPUArchitecture/RAM/storage Virtual Machine with 4 GB Ram
- OS: what OS is used and which version Ubuntu Server 20.04
- Java Runtime Environment: which java platform is used and what version Zulu
- openHAB version: 3.0.0
