You would hope that was plenty of time, but I guess not in reality.
I’d assume a Windows box would be more powerful than the usual Pi - this may be contributing to your view of the issue - multi-core processors would make this a more chaotic process than on a plodding Pi.
There’s some kind of tweak the Openabian guys use about file loading process, worth digging up.
I developed my first set of OH1 rules on a slow laptop - these failed when transferred to a more powerful desktop, all sorts of race conditions were exposed.
I’m not sure how well that approach will translate to a Windows machine. Essentially the systemd start script has some commands in it that move the .rules files out of the rules folder, sleeps for a bit and then moved them back. The sleep is long enough for everything else to finish loading before the Rules are loaded.
There really isn’t an equivalent to a systemd service file on Windows. Maybe one could do this in the start.bat file?
Thanks for explanation. My max shutter contacts are in two groups (CLOSED/OPEN) named WindowsEG and WindowsUG. The last update (DateTime) comes from a rule (see above). When I stop max binding then the spaming of logfile stops. The rule run for nearly 3 years. Then rule engine must have been changed or made more restricted. The low battery states (ON/OFF) of the shutter contacts are in the same both groups.
Maybe that now is the problem?
EDIT: I’ve removed “low battery states (ON/OFF)” items from both groups, now. SAME problem.
// Creates an item that stores the last update time of this item
rule "Records last windows EG update time"
Item WindowsEG received update
WindowsEG_LastUpdate.postUpdate(new DateTimeType())
rule "Records last windows UG update time"
Item WindowsUG received update
WindowsUG_LastUpdate.postUpdate(new DateTimeType())
. LOG:
2020-02-01 17:54:08.166 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:53:31.878+0100 to 2020-02-01T17:54:08.101+0100
2020-02-01 17:54:08.168 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.101+0100 to 2020-02-01T17:54:08.102+0100
2020-02-01 17:54:08.169 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.102+0100 to 2020-02-01T17:54:08.104+0100
2020-02-01 17:54:08.171 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.104+0100 to 2020-02-01T17:54:08.105+0100
2020-02-01 17:54:08.172 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.105+0100 to 2020-02-01T17:54:08.106+0100
2020-02-01 17:54:08.173 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.106+0100 to 2020-02-01T17:54:08.108+0100
2020-02-01 17:54:08.174 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.108+0100 to 2020-02-01T17:54:08.101+0100
2020-02-01 17:54:08.175 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.101+0100 to 2020-02-01T17:54:08.102+0100
2020-02-01 17:54:08.176 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:53:31.878+0100 to 2020-02-01T17:54:08.104+0100
2020-02-01 17:54:08.178 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.102+0100 to 2020-02-01T17:54:08.105+0100
2020-02-01 17:54:08.179 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.105+0100 to 2020-02-01T17:54:08.106+0100
2020-02-01 17:54:08.180 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.106+0100 to 2020-02-01T17:54:08.102+0100
2020-02-01 17:54:08.181 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.102+0100 to 2020-02-01T17:54:08.103+0100
2020-02-01 17:54:08.182 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.103+0100 to 2020-02-01T17:54:08.104+0100
2020-02-01 17:54:08.299 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.104+0100 to 2020-02-01T17:54:08.106+0100
2020-02-01 17:54:08.301 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.106+0100 to 2020-02-01T17:54:08.107+0100
2020-02-01 17:54:08.303 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.107+0100 to 2020-02-01T17:54:08.108+0100
2020-02-01 17:54:08.312 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.108+0100 to 2020-02-01T17:54:08.107+0100
2020-02-01 17:54:08.314 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.107+0100 to 2020-02-01T17:54:08.108+0100
2020-02-01 17:54:08.316 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.108+0100 to 2020-02-01T17:54:08.109+0100
2020-02-01 17:54:08.318 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.109+0100 to 2020-02-01T17:54:08.111+0100
2020-02-01 17:54:08.328 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.111+0100 to 2020-02-01T17:54:08.112+0100
2020-02-01 17:54:08.330 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.104+0100 to 2020-02-01T17:54:08.111+0100
2020-02-01 17:54:08.464 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.111+0100 to 2020-02-01T17:54:08.110+0100
2020-02-01 17:54:08.465 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.112+0100 to 2020-02-01T17:54:08.114+0100
2020-02-01 17:54:08.467 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.114+0100 to 2020-02-01T17:54:08.116+0100
2020-02-01 17:54:08.469 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.116+0100 to 2020-02-01T17:54:08.113+0100
2020-02-01 17:54:08.470 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.113+0100 to 2020-02-01T17:54:08.115+0100
2020-02-01 17:54:08.471 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.115+0100 to 2020-02-01T17:54:08.116+0100
2020-02-01 17:54:08.741 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.110+0100 to 2020-02-01T17:54:08.116+0100
2020-02-01 17:54:08.743 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.116+0100 to 2020-02-01T17:54:08.117+0100
2020-02-01 17:54:08.744 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.117+0100 to 2020-02-01T17:54:08.118+0100
2020-02-01 17:54:08.745 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.118+0100 to 2020-02-01T17:54:08.120+0100
2020-02-01 17:54:08.746 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.120+0100 to 2020-02-01T17:54:08.121+0100
2020-02-01 17:54:08.748 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.116+0100 to 2020-02-01T17:54:08.122+0100
2020-02-01 17:54:08.749 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.122+0100 to 2020-02-01T17:54:08.123+0100
2020-02-01 17:54:08.750 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.121+0100 to 2020-02-01T17:54:08.117+0100
2020-02-01 17:54:08.751 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.117+0100 to 2020-02-01T17:54:08.118+0100
2020-02-01 17:54:08.753 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.118+0100 to 2020-02-01T17:54:08.119+0100
2020-02-01 17:54:08.754 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.119+0100 to 2020-02-01T17:54:08.120+0100
2020-02-01 17:54:08.755 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.120+0100 to 2020-02-01T17:54:08.121+0100
2020-02-01 17:54:08.757 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.121+0100 to 2020-02-01T17:54:08.122+0100
2020-02-01 17:54:08.758 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.122+0100 to 2020-02-01T17:54:08.123+0100
2020-02-01 17:54:08.759 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.123+0100 to 2020-02-01T17:54:08.124+0100
2020-02-01 17:54:08.760 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.123+0100 to 2020-02-01T17:54:08.125+0100
2020-02-01 17:54:08.761 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.125+0100 to 2020-02-01T17:54:08.127+0100
2020-02-01 17:54:08.762 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.127+0100 to 2020-02-01T17:54:08.125+0100
2020-02-01 17:54:08.764 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.125+0100 to 2020-02-01T17:54:08.127+0100
2020-02-01 17:54:08.765 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.127+0100 to 2020-02-01T17:54:08.128+0100
2020-02-01 17:54:08.766 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.124+0100 to 2020-02-01T17:54:08.129+0100
2020-02-01 17:54:08.767 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.128+0100 to 2020-02-01T17:54:08.130+0100
2020-02-01 17:54:08.768 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.130+0100 to 2020-02-01T17:54:08.131+0100
2020-02-01 17:54:08.769 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.131+0100 to 2020-02-01T17:54:08.132+0100
2020-02-01 17:54:08.770 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.132+0100 to 2020-02-01T17:54:08.133+0100
2020-02-01 17:54:08.820 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.133+0100 to 2020-02-01T17:54:08.134+0100
2020-02-01 17:54:08.822 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.129+0100 to 2020-02-01T17:54:08.136+0100
2020-02-01 17:54:08.823 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.136+0100 to 2020-02-01T17:54:08.137+0100
2020-02-01 17:54:08.824 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.134+0100 to 2020-02-01T17:54:08.138+0100
2020-02-01 17:54:08.826 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.138+0100 to 2020-02-01T17:54:08.139+0100
2020-02-01 17:54:08.828 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.139+0100 to 2020-02-01T17:54:08.128+0100
2020-02-01 17:54:08.829 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.137+0100 to 2020-02-01T17:54:08.129+0100
2020-02-01 17:54:08.831 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.128+0100 to 2020-02-01T17:54:08.130+0100
2020-02-01 17:54:08.833 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.130+0100 to 2020-02-01T17:54:08.132+0100
2020-02-01 17:54:08.834 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.132+0100 to 2020-02-01T17:54:08.133+0100
2020-02-01 17:54:08.839 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.133+0100 to 2020-02-01T17:54:08.134+0100
2020-02-01 17:54:08.841 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.134+0100 to 2020-02-01T17:54:08.135+0100
2020-02-01 17:54:08.847 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.135+0100 to 2020-02-01T17:54:08.136+0100
2020-02-01 17:54:09.151 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.129+0100 to 2020-02-01T17:54:08.138+0100
2020-02-01 17:54:09.172 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.136+0100 to 2020-02-01T17:54:08.139+0100
2020-02-01 17:54:09.288 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.139+0100 to 2020-02-01T17:54:08.142+0100
2020-02-01 17:54:09.309 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.142+0100 to 2020-02-01T17:54:08.156+0100
2020-02-01 17:54:09.314 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.156+0100 to 2020-02-01T17:54:08.157+0100
2020-02-01 17:54:09.322 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.157+0100 to 2020-02-01T17:54:08.112+0100
2020-02-01 17:54:09.329 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.138+0100 to 2020-02-01T17:54:08.141+0100
2020-02-01 17:54:09.334 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.112+0100 to 2020-02-01T17:54:08.142+0100
2020-02-01 17:54:09.336 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.142+0100 to 2020-02-01T17:54:08.143+0100
2020-02-01 17:54:09.338 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.143+0100 to 2020-02-01T17:54:08.144+0100
2020-02-01 17:54:09.340 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.144+0100 to 2020-02-01T17:54:08.145+0100
2020-02-01 17:54:09.342 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.145+0100 to 2020-02-01T17:54:08.147+0100
2020-02-01 17:54:09.344 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.147+0100 to 2020-02-01T17:54:08.148+0100
2020-02-01 17:54:09.347 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.148+0100 to 2020-02-01T17:54:08.149+0100
2020-02-01 17:54:09.349 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.149+0100 to 2020-02-01T17:54:08.150+0100
2020-02-01 17:54:09.351 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.150+0100 to 2020-02-01T17:54:08.151+0100
2020-02-01 17:54:09.367 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.141+0100 to 2020-02-01T17:54:08.152+0100
2020-02-01 17:54:09.370 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.152+0100 to 2020-02-01T17:54:08.154+0100
2020-02-01 17:54:09.384 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.151+0100 to 2020-02-01T17:54:08.155+0100
2020-02-01 17:54:09.387 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.155+0100 to 2020-02-01T17:54:08.125+0100
2020-02-01 17:54:09.388 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.125+0100 to 2020-02-01T17:54:08.173+0100
2020-02-01 17:54:09.390 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.173+0100 to 2020-02-01T17:54:08.174+0100
2020-02-01 17:54:09.393 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.174+0100 to 2020-02-01T17:54:08.175+0100
2020-02-01 17:54:09.395 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.175+0100 to 2020-02-01T17:54:08.177+0100
2020-02-01 17:54:09.398 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.177+0100 to 2020-02-01T17:54:08.178+0100
2020-02-01 17:54:09.401 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.178+0100 to 2020-02-01T17:54:08.180+0100
2020-02-01 17:54:09.404 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.180+0100 to 2020-02-01T17:54:08.181+0100
2020-02-01 17:54:09.406 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.181+0100 to 2020-02-01T17:54:08.182+0100
2020-02-01 17:54:09.407 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.182+0100 to 2020-02-01T17:54:08.205+0100
2020-02-01 17:54:09.409 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.205+0100 to 2020-02-01T17:54:08.206+0100
2020-02-01 17:54:09.411 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.154+0100 to 2020-02-01T17:54:08.207+0100
2020-02-01 17:54:09.416 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.206+0100 to 2020-02-01T17:54:08.183+0100
2020-02-01 17:54:09.426 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.183+0100 to 2020-02-01T17:54:08.207+0100
2020-02-01 17:54:09.428 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.207+0100 to 2020-02-01T17:54:08.208+0100
2020-02-01 17:54:09.431 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.208+0100 to 2020-02-01T17:54:08.209+0100
2020-02-01 17:54:09.433 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.209+0100 to 2020-02-01T17:54:08.210+0100
2020-02-01 17:54:09.436 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.210+0100 to 2020-02-01T17:54:08.212+0100
2020-02-01 17:54:09.443 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.212+0100 to 2020-02-01T17:54:08.213+0100
2020-02-01 17:54:09.444 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.213+0100 to 2020-02-01T17:54:08.208+0100
2020-02-01 17:54:09.447 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.208+0100 to 2020-02-01T17:54:08.214+0100
2020-02-01 17:54:09.449 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.214+0100 to 2020-02-01T17:54:08.215+0100
2020-02-01 17:54:09.451 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.215+0100 to 2020-02-01T17:54:08.216+0100
2020-02-01 17:54:09.667 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.216+0100 to 2020-02-01T17:54:08.218+0100
2020-02-01 17:54:09.669 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.218+0100 to 2020-02-01T17:54:08.219+0100
2020-02-01 17:54:09.676 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.219+0100 to 2020-02-01T17:54:08.220+0100
2020-02-01 17:54:09.680 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.220+0100 to 2020-02-01T17:54:08.222+0100
2020-02-01 17:54:09.685 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.222+0100 to 2020-02-01T17:54:08.223+0100
2020-02-01 17:54:09.689 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.223+0100 to 2020-02-01T17:54:08.225+0100
2020-02-01 17:54:09.695 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.225+0100 to 2020-02-01T17:54:08.226+0100
2020-02-01 17:54:09.700 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.226+0100 to 2020-02-01T17:54:08.227+0100
2020-02-01 17:54:09.702 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.227+0100 to 2020-02-01T17:54:08.228+0100
2020-02-01 17:54:09.706 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.228+0100 to 2020-02-01T17:54:08.232+0100
2020-02-01 17:54:09.710 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.207+0100 to 2020-02-01T17:54:08.234+0100
2020-02-01 17:54:09.713 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.232+0100 to 2020-02-01T17:54:08.239+0100
2020-02-01 17:54:09.716 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.239+0100 to 2020-02-01T17:54:08.241+0100
2020-02-01 17:54:09.720 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.241+0100 to 2020-02-01T17:54:08.242+0100
2020-02-01 17:54:09.723 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.234+0100 to 2020-02-01T17:54:08.244+0100
2020-02-01 17:54:09.728 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.242+0100 to 2020-02-01T17:54:08.245+0100
2020-02-01 17:54:09.731 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.244+0100 to 2020-02-01T17:54:08.247+0100
2020-02-01 17:54:09.738 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.245+0100 to 2020-02-01T17:54:08.248+0100
2020-02-01 17:54:09.750 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.248+0100 to 2020-02-01T17:54:08.250+0100
2020-02-01 17:54:09.758 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.250+0100 to 2020-02-01T17:54:08.252+0100
2020-02-01 17:54:09.816 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.252+0100 to 2020-02-01T17:54:08.253+0100
2020-02-01 17:54:09.821 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.253+0100 to 2020-02-01T17:54:08.255+0100
2020-02-01 17:54:09.826 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.247+0100 to 2020-02-01T17:54:08.256+0100
2020-02-01 17:54:09.830 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.255+0100 to 2020-02-01T17:54:08.258+0100
2020-02-01 17:54:09.852 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.258+0100 to 2020-02-01T17:54:08.259+0100
2020-02-01 17:54:09.857 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.259+0100 to 2020-02-01T17:54:08.263+0100
2020-02-01 17:54:09.864 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.263+0100 to 2020-02-01T17:54:08.264+0100
2020-02-01 17:54:09.869 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.264+0100 to 2020-02-01T17:54:08.266+0100
2020-02-01 17:54:09.874 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.266+0100 to 2020-02-01T17:54:08.267+0100
2020-02-01 17:54:09.879 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.267+0100 to 2020-02-01T17:54:08.269+0100
2020-02-01 17:54:09.887 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.269+0100 to 2020-02-01T17:54:08.271+0100
2020-02-01 17:54:09.893 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.271+0100 to 2020-02-01T17:54:08.272+0100
2020-02-01 17:54:09.896 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.272+0100 to 2020-02-01T17:54:08.274+0100
2020-02-01 17:54:09.921 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.274+0100 to 2020-02-01T17:54:08.275+0100
2020-02-01 17:54:09.924 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.275+0100 to 2020-02-01T17:54:08.277+0100
2020-02-01 17:54:09.929 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.277+0100 to 2020-02-01T17:54:08.158+0100
2020-02-01 17:54:09.937 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.256+0100 to 2020-02-01T17:54:08.280+0100
2020-02-01 17:54:09.942 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.158+0100 to 2020-02-01T17:54:08.278+0100
2020-02-01 17:54:09.944 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.278+0100 to 2020-02-01T17:54:08.282+0100
2020-02-01 17:54:09.946 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.282+0100 to 2020-02-01T17:54:08.284+0100
2020-02-01 17:54:09.948 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.284+0100 to 2020-02-01T17:54:08.285+0100
2020-02-01 17:54:09.950 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.285+0100 to 2020-02-01T17:54:08.287+0100
2020-02-01 17:54:09.952 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.287+0100 to 2020-02-01T17:54:08.288+0100
2020-02-01 17:54:09.958 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.288+0100 to 2020-02-01T17:54:08.289+0100
2020-02-01 17:54:09.959 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.289+0100 to 2020-02-01T17:54:08.290+0100
2020-02-01 17:54:09.960 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.290+0100 to 2020-02-01T17:54:08.292+0100
2020-02-01 17:54:10.091 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.292+0100 to 2020-02-01T17:54:08.293+0100
2020-02-01 17:54:10.098 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.293+0100 to 2020-02-01T17:54:08.294+0100
2020-02-01 17:54:10.102 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.280+0100 to 2020-02-01T17:54:08.296+0100
2020-02-01 17:54:10.104 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.296+0100 to 2020-02-01T17:54:08.297+0100
2020-02-01 17:54:10.107 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.294+0100 to 2020-02-01T17:54:08.298+0100
2020-02-01 17:54:10.112 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.298+0100 to 2020-02-01T17:54:08.300+0100
2020-02-01 17:54:10.257 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.300+0100 to 2020-02-01T17:54:08.301+0100
2020-02-01 17:54:10.259 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.301+0100 to 2020-02-01T17:54:08.359+0100
2020-02-01 17:54:10.260 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.297+0100 to 2020-02-01T17:54:08.361+0100
2020-02-01 17:54:10.331 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.359+0100 to 2020-02-01T17:54:08.362+0100
2020-02-01 17:54:10.333 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.362+0100 to 2020-02-01T17:54:08.366+0100
2020-02-01 17:54:10.342 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.366+0100 to 2020-02-01T17:54:08.262+0100
2020-02-01 17:54:10.344 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.262+0100 to 2020-02-01T17:54:08.361+0100
2020-02-01 17:54:10.347 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.361+0100 to 2020-02-01T17:54:08.355+0100
2020-02-01 17:54:10.349 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.355+0100 to 2020-02-01T17:54:08.362+0100
2020-02-01 17:54:10.351 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.362+0100 to 2020-02-01T17:54:08.364+0100
2020-02-01 17:54:10.353 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.364+0100 to 2020-02-01T17:54:08.365+0100
2020-02-01 17:54:10.354 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.361+0100 to 2020-02-01T17:54:08.366+0100
2020-02-01 17:54:10.356 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.365+0100 to 2020-02-01T17:54:08.367+0100
2020-02-01 17:54:10.358 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.367+0100 to 2020-02-01T17:54:08.368+0100
2020-02-01 17:54:10.359 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.368+0100 to 2020-02-01T17:54:08.369+0100
2020-02-01 17:54:10.361 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.366+0100 to 2020-02-01T17:54:08.369+0100
2020-02-01 17:54:10.363 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.369+0100 to 2020-02-01T17:54:08.370+0100
2020-02-01 17:54:10.434 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.370+0100 to 2020-02-01T17:54:08.354+0100
2020-02-01 17:54:10.438 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.354+0100 to 2020-02-01T17:54:08.368+0100
2020-02-01 17:54:10.439 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.368+0100 to 2020-02-01T17:54:08.369+0100
2020-02-01 17:54:10.441 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.369+0100 to 2020-02-01T17:54:08.370+0100
2020-02-01 17:54:10.444 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.369+0100 to 2020-02-01T17:54:08.371+0100
2020-02-01 17:54:10.446 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.371+0100 to 2020-02-01T17:54:08.373+0100
2020-02-01 17:54:10.459 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.373+0100 to 2020-02-01T17:54:08.374+0100
2020-02-01 17:54:10.461 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.374+0100 to 2020-02-01T17:54:08.375+0100
2020-02-01 17:54:10.463 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.375+0100 to 2020-02-01T17:54:08.376+0100
2020-02-01 17:54:10.466 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.376+0100 to 2020-02-01T17:54:08.377+0100
2020-02-01 17:54:10.473 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.377+0100 to 2020-02-01T17:54:08.379+0100
2020-02-01 17:54:10.475 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.379+0100 to 2020-02-01T17:54:08.380+0100
2020-02-01 17:54:10.479 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.380+0100 to 2020-02-01T17:54:08.383+0100
2020-02-01 17:54:10.481 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.383+0100 to 2020-02-01T17:54:08.372+0100
2020-02-01 17:54:10.485 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.372+0100 to 2020-02-01T17:54:08.374+0100
2020-02-01 17:54:10.487 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.374+0100 to 2020-02-01T17:54:08.375+0100
2020-02-01 17:54:10.489 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.375+0100 to 2020-02-01T17:54:08.376+0100
2020-02-01 17:54:10.490 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.376+0100 to 2020-02-01T17:54:08.377+0100
2020-02-01 17:54:10.493 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.377+0100 to 2020-02-01T17:54:08.378+0100
2020-02-01 17:54:10.494 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.378+0100 to 2020-02-01T17:54:08.379+0100
2020-02-01 17:54:10.497 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.379+0100 to 2020-02-01T17:54:08.380+0100
2020-02-01 17:54:10.499 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.380+0100 to 2020-02-01T17:54:08.381+0100
2020-02-01 17:54:10.502 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.381+0100 to 2020-02-01T17:54:08.382+0100
2020-02-01 17:54:10.504 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.370+0100 to 2020-02-01T17:54:08.383+0100
2020-02-01 17:54:10.506 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.383+0100 to 2020-02-01T17:54:08.384+0100
2020-02-01 17:54:10.507 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.382+0100 to 2020-02-01T17:54:08.386+0100
2020-02-01 17:54:10.511 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.386+0100 to 2020-02-01T17:54:08.387+0100
2020-02-01 17:54:10.513 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.387+0100 to 2020-02-01T17:54:08.388+0100
2020-02-01 17:54:10.516 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.388+0100 to 2020-02-01T17:54:08.390+0100
2020-02-01 17:54:10.521 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.390+0100 to 2020-02-01T17:54:08.391+0100
2020-02-01 17:54:10.523 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.391+0100 to 2020-02-01T17:54:08.392+0100
2020-02-01 17:54:10.524 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.392+0100 to 2020-02-01T17:54:08.393+0100
2020-02-01 17:54:10.539 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.393+0100 to 2020-02-01T17:54:08.394+0100
2020-02-01 17:54:10.543 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.394+0100 to 2020-02-01T17:54:08.395+0100
2020-02-01 17:54:10.546 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.384+0100 to 2020-02-01T17:54:08.394+0100
2020-02-01 17:54:10.551 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.395+0100 to 2020-02-01T17:54:08.396+0100
2020-02-01 17:54:10.575 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.396+0100 to 2020-02-01T17:54:08.397+0100
2020-02-01 17:54:10.577 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.397+0100 to 2020-02-01T17:54:08.398+0100
2020-02-01 17:54:10.580 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.394+0100 to 2020-02-01T17:54:08.397+0100
2020-02-01 17:54:10.582 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.398+0100 to 2020-02-01T17:54:08.399+0100
2020-02-01 17:54:10.585 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.399+0100 to 2020-02-01T17:54:08.400+0100
2020-02-01 17:54:10.587 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.400+0100 to 2020-02-01T17:54:08.401+0100
2020-02-01 17:54:10.588 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.401+0100 to 2020-02-01T17:54:08.402+0100
2020-02-01 17:54:10.591 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.402+0100 to 2020-02-01T17:54:08.403+0100
2020-02-01 17:54:10.593 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.403+0100 to 2020-02-01T17:54:08.404+0100
2020-02-01 17:54:10.596 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.404+0100 to 2020-02-01T17:54:08.405+0100
2020-02-01 17:54:10.601 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.397+0100 to 2020-02-01T17:54:08.404+0100
2020-02-01 17:54:10.604 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.405+0100 to 2020-02-01T17:54:08.407+0100
2020-02-01 17:54:10.610 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.404+0100 to 2020-02-01T17:54:08.407+0100
2020-02-01 17:54:10.612 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.407+0100 to 2020-02-01T17:54:08.408+0100
2020-02-01 17:54:10.615 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.407+0100 to 2020-02-01T17:54:08.408+0100
2020-02-01 17:54:10.618 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.408+0100 to 2020-02-01T17:54:08.409+0100
2020-02-01 17:54:10.627 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.409+0100 to 2020-02-01T17:54:08.410+0100
2020-02-01 17:54:10.772 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.410+0100 to 2020-02-01T17:54:08.411+0100
2020-02-01 17:54:10.775 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.411+0100 to 2020-02-01T17:54:08.412+0100
2020-02-01 17:54:10.778 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.412+0100 to 2020-02-01T17:54:08.413+0100
2020-02-01 17:54:10.780 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.413+0100 to 2020-02-01T17:54:08.414+0100
2020-02-01 17:54:10.782 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.414+0100 to 2020-02-01T17:54:08.415+0100
2020-02-01 17:54:10.784 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.415+0100 to 2020-02-01T17:54:08.416+0100
2020-02-01 17:54:10.785 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.416+0100 to 2020-02-01T17:54:08.415+0100
2020-02-01 17:54:10.787 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.415+0100 to 2020-02-01T17:54:08.416+0100
2020-02-01 17:54:10.788 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.416+0100 to 2020-02-01T17:54:08.417+0100
2020-02-01 17:54:10.790 [vent.ItemStateChangedEvent] - WindowsUG_LastUpdate changed from 2020-02-01T17:54:08.408+0100 to 2020-02-01T17:54:08.417+0100
2020-02-01 17:54:10.792 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.417+0100 to 2020-02-01T17:54:08.413+0100
2020-02-01 17:54:10.794 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.413+0100 to 2020-02-01T17:54:08.419+0100
2020-02-01 17:54:10.795 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.419+0100 to 2020-02-01T17:54:08.418+0100
2020-02-01 17:54:10.797 [vent.ItemStateChangedEvent] - WindowsEG_LastUpdate changed from 2020-02-01T17:54:08.418+0100 to 2020-02-01T17:54:08.419+0100
First of all, I want to rule out that it is a rules problem or another problem. It would be an advantage if someone else has the same problem with the max binding. Maybe someone else can retrace it on his system? Just copy my config… :-
First remove your cube thing and let it be discovered again.
Than check your cube Refresh Interval, set it to 30 seconds or so (this should be standard).
Than suggest to enable the debugging of the max binding. log:set DEBUG org.openhab.binding.max and check the log.
Check what is happening here. The updates should happen at each refresh (so 30 seconds if you set it refresh interval as above)
If it continues please PM me your log or paste it in Github.
The old binding always told: No changes for… (if there where no changes)
And the new binding is telling: Updating states for… (No matter if the state has changed)
I’ve changed my rules to:
Item WindowsEG changed
Item WindowsUG changed
