[SOLVED] Rules execbindings DHT11 String
Hi everbody i’m new with rules in openhab2 and execbindings value return.
I would like that i can turn off a LED when mt temperature from my DHT11 reaches 24°C.
This is are my files.
weatherstation.py
    #!/usr/bin/env python3
    # -*- coding: utf-8 -*-
    import Adafruit_BMP.BMP085 as BMP085
    import Adafruit_DHT
    import sys, time
    # constants
   DHT_PIN = 4                    # GPIO nr
   DHT_SENSOR = Adafruit_DHT.DHT11
    if __name__ == '__main__':
      if len(sys.argv) > 1:
        call = sys.argv[1].lower()
         if call == 'temperature':
            temperature = None
            while temperature == None:
               _, temperature = Adafruit_DHT.read_retry(DHT_SENSOR, DHT_PIN)
               if temperature == None:
                   time.sleep(1.0)
            print(temperature)
weatherstation.items
    Group  Weatherstation_Chart (System, Charts)
    Number Weatherstation_Chart_Period "Periode" (System)
    Number Weatherstation_Temperature "Temperatura [%.1f °C]" <temperature> (Weatherstation_Chart)
    String temperature_out { channel="exec:command:weatherstation_temperature:output" }
    Switch LED{ gpio="pin:26" }
This is my rule but doesn’t work sure i have written something wrong in the return of the TEMP variable
weatherstation.rules
rule "termostato"
     Item temperature_out received update
    val TEMP=executeCommandLine("python /etc/openhab2/scripts/weatherstation.py
  temperature",5000)
    if (TEMP.toString().length > 24) LED.sendCommand(OFF)
Somebody can help?
Please fix your code fences. Your post is very difficult to read.
Here
Thanks! It is all new for me, hope it’s correct
Thanks for fixing your code fences :+1:
Add some logging to debug your rule:
logInfo("termostato", TEMP)
You try to trigger the rule, with a item which is never updated.
You also miss the item file. An example explaining the exec binding.
rule "termostato"
    if (  Float.parseFloat( Temperaturen_out.state) > 24) {
Something like this. Not tested typed in my phone, may contain typos.
@warlock Edit:
Your thing looks good and the Eule gets triggered as you geht the logging.
Now parse string to float, the output value of exec is a string, which can not be compared to a number.
Can you toggle the led with a switch? Does the led work?
Removed triggeringItem since it works only with at least openhab 2.2.
@luckymallari this is what i get from the log
openhab> log:tail  org.eclipse.smarthome.model.script.termostato
22:06:51.300 [INFO ] [pse.smarthome.model.script.termostato] -
22:06:58.911 [INFO ] [pse.smarthome.model.script.termostato] - 26.0
22:07:09.805 [INFO ] [pse.smarthome.model.script.termostato] - 26.0
22:07:25.820 [INFO ] [pse.smarthome.model.script.termostato] - 25.0
22:07:36.503 [INFO ] [pse.smarthome.model.script.termostato] - 26.0
22:07:47.517 [INFO ] [pse.smarthome.model.script.termostato] - 25.0
22:07:58.411 [INFO ] [pse.smarthome.model.script.termostato] - 25.0
22:08:15.090 [INFO ] [pse.smarthome.model.script.termostato] -
But the LED doesn't go off.
I forgot to post the
weatherstation.thing , sorry @Josar
Thing exec:command:weatherstation_temperature “Temperatura” [command="/etc/openhab2/scripts/weatherstation.py temperature", transform=“REGEX((.*?))”, interval=10, timeout=10, autorun=true]
@Josar i have tried to use your rule with my thing file but still nothing.
I’ll study the Tutorials & Examples you posted.
Let you know.
Post your actual rule (latest you have after suggestions above)
Maybe it has to look somehow like that.
rule "termostato"
    if (  Float.parseFloat( Temperaturen_out.state.toString)  as Decimal > 24) {
received update
NOT
receiver update
Hi to all,
@Josar no the code you posted doesn’t produce results and let rules file not accepted.
I found some code in
https://tutorials-raspberrypi.de/raspberry-pi-wetterstation-bauen-openhab2/
So i made some upgrades.
I use a DHT11 (for temperature and humidity) and a BMP180 (for pressure)
Number Weatherstation_Humidity    "Umidità [%.1f %%]" <humidity> (Weatherstation_Chart)
Number Weatherstation_Pressure    "Pressione [%.1f hPa]" <pressure> (Weatherstation_Chart)
String humidity_out    { channel="exec:command:weatherstation_humidity:output" }
String pressure_out    { channel="exec:command:weatherstation_pressure:output" }
Switch RELE1{ gpio="pin:20" }
Switch RELE2{ gpio="pin:21" }
Thing exec:command:weatherstation_temperature "Temperatura"    [command="/etc/openhab2/scripts/weatherstation.py temperature", transform="REGEX((.*?))", interval=2, timeout=10, autorun=true]
Thing exec:command:weatherstation_humidity "Umidità" [command="/etc/openhab2/scripts/weatherstation.py humidity",    transform="REGEX((.*?))", interval=2, timeout=10, autorun=true]
Thing exec:command:weatherstation_pressure "Pressione"        [command="/etc/openhab2/scripts/weatherstation.py pressure",    transform="REGEX((.*?))", interval=2, timeout=10, autorun=true]
import Adafruit_DHT
import sys, time
# constants
            temperature = None
                   time.sleep(1.0)
            print(temperature)
        elif call == 'humidity':
            humidity = None
            while humidity == None:
               humidity, _ = Adafruit_DHT.read_retry(DHT_SENSOR, DHT_PIN)
               if humidity == None:
                   time.sleep(1.0)
            print(humidity)
        elif call == 'pressure':
            sensor = BMP085.BMP085()
            print(sensor.read_pressure() / 100.0)
And here we are , i managed to get rules to work ( code under), I realy don’t know what the code means
( ( Float::parseFloat(temperature_out.state.toString) as Number ) * 10 ) / 10
and how to use it with sense i tried a cut and paste and now it works.
I would only like to know ho to get the value as a number o decimal so to be used in any rule, i don’t think the by 10 and the division by 10 are necessary. Plus like this i get temperatures in decimal it would be nice to have even to have values with one digit after the comma, like
24,1 24,5 …
I know I have to get more knowhow, would you like to give me some advice and interpretation of the code? Or improvements
rule "Weatherstation Temperatura"
      Weatherstation_Temperature.postUpdate(
rule "Weatherstation Umidità"
     Item humidity_out received update
      Weatherstation_Humidity.postUpdate(
          ( ( Float::parseFloat(humidity_out.state.toString) as Number ) * 10 ) / 10
rule "Weatherstation Pressione"
     Item pressure_out received update
      Weatherstation_Pressure.postUpdate(
          ( ( Float::parseFloat(pressure_out.state.toString) as Number ) * 10 ) / 10
rule "RELE 1 ON"
  Item LED changed from OFF to ON
  RELE1.sendCommand(ON)
rule "RELE 1 OFF"
  Item LED changed from ON to OFF
  RELE1.sendCommand(OFF)
rule "termostato"
      if (((( Float::parseFloat(temperature_out.state.toString) as Number ) * 10 ) / 10)>24) {
rule "termostato"
      if (((( Float::parseFloat(temperature_out.state.toString) as Number ) * 10 ) / 10)<=24) {
    LED.sendCommand(ON)
sitemap weatherstation label="Raspberry Pi Stazione Meteo"
	 Frame label="LED"
	   Switch item=LED
	 Frame label="Relè"
	   Switch item=RELE1
	   Switch item=RELE2
        Frame label="Meteo" {
            Text item=Weatherstation_Temperature
            Text item=Weatherstation_Humidity
            Text item=Weatherstation_Pressure
        Frame {
            Switch item=Weatherstation_Chart_Period mappings=[0="1h", 1="4h", 2="8h", 3="12h", 4="24h"]
            Chart  item=Weatherstation_Chart period=h   refresh=60000 visibility=[Weatherstation_Chart_Period==0, Weatherstation_Chart_Period=="Uninitialized"]
            Chart  item=Weatherstation_Chart period=4h  refresh=60000 visibility=[Weatherstation_Chart_Period==1]
            Chart  item=Weatherstation_Chart period=8h  refresh=60000 visibility=[Weatherstation_Chart_Period==2]
            Chart  item=Weatherstation_Chart period=12h refresh=60000 visibility=[Weatherstation_Chart_Period==3]
            Chart  item=Weatherstation_Chart period=D   refresh=60000 visibility=[Weatherstation_Chart_Period==4]
@warlock so got time to sit down and make a quick test by implementing a DS18B20 oneWire Temperature sensor.
This works for me.
        if( Float.parseFloat(triggeringItem.state.toString) > 25){
            logInfo("------------", " bigger")
        }else {
            logInfo("------------", " smaller")
Also have a look here for some more info on how to reduce your rules.
