I created two rules using the PaperUI rules creator. They are simple,(1) if a button on an GPIO pin is pressed, turn on an LED on another pin. (2) When the button is released, turn off the LED.
Everything works fine until I reboot. Then the LED won’t turn on. All I have to do is go back to the rules creator and just open each rule like I would edit it but close it without making any changes. After that process both rules work again.
What can I do to keep the rules working after a reboot?
