Rules File Help for ADB FireStick
Great, thanks for sharing. I am differently interested in seeing the finished product.
no luck getting this working better yet?
trying to get it working without success, you can give an example of your items file? thanks in advance
I have since moved into a new place and haven’t had much time to work on this. I have quite a bit of time in the upcoming weeks, and plan on nuking the entire automation system and starting from scratch to clean it up. I’ll post in this thread again once I get the system working.
I’ve moved since the original thread posts. I plan on starting from scratch in the next few weeks and will further optimize the implementation of this. I’ll post a guide on it once I’ve got it working. (If you don’t see something in this thread by january bug me about it…)
ok, thank you very much, i will stay tuned on this post, i have all the scripts working from terminal, i had implement other commands too, if you need it will share it here
Have any updates?
Is it possible to turn on tv with custom rule ? If yes what would be the rule.
With my current tv binding and can control everything from OH as soon the tv is switched on, but OH won’t switch on tv in the first place - my tv doesn’t not support WOL.
So if I could get fire stick tv to turn on this unit that would be brilliant, saves me a hassle going down broadlink solution.
