Java Runtime Environment: which java platform is used and what version
openHAB version: openhab3
Issue of the topic: please be detailed explaining your issue
Please post configurations (if applicable):
Items configuration related to the issue
Sitemap configuration related to the issue
Rules code related to the issue
Services configuration related to the issue
If logs where generated please post these here using code fences:
Hi everyone I need some helps to get my sun blinds working properly on weather conditions.
In particular I would like them get back on strong wind and rains.
Tried to get this rules triggered on local weather things on channel winds speed over 11km/h but it doesn’t work. I wrote this rules with UI to get a item switch on or off according wind speed but nothing happens.
what should happen exactly? Should the blinds go up at strong winds AND rain or also when one of both happens? This is important to know whether it is a AND or OR rule.
Afaik you can’t use the > as state. You need to set this as a codition (But only if).
Maybe you can describe what should happen exactly under which circumstances?
Hi and thanks for your reply.
I would like that the blinds goes up with one of this conditions strong winds (>11km/h)or rain as I don’t have a sensor I would like to use the local weather information as virtual sensor.
You can create 2 rules.
In your first rule the trigger is the rain. So the rule will be triggered everytime the rain state changed.
In your second rule the tigger is the wind (changed state to any) and the condition is greater or equal to your windspeed (in your case 11).
You can also combine the two rules into one with a blocky script.
The trigger is the rain and the wind (so both will trigger the rule) with a state changed to any.
As action you create a blocky script like this where the blinds only move IF the wind is greater or equal to 11 OR the rain is ON (on = it is raining in my case)
