I am trying to use a rule (in openhab 2 Paper UI)… When… it is a fixed time of a day… but it is not triggering the role.
NTP binding is already installed, should I install or setup something else?
I found (using Karaf) that the configurations of Experimental Rules were doubled!!! This was also the case for MQTT binding. I do why!? Therefore
1- I uninstalled it (Experimental Rules and MQTT binding)
2- Open Karaf "ssh -p 8101 openhab@localhost"
3- Get list of installed bindings using "config:property-list"
4- You can clean/delete the wanted bindings (ex. config:delete org.openhab.mqtt)
5- Restart OH2
6- Then over Paper UI re-install The Experimental Rules
At least in my case, the above steps solved my problem
