Hallo all,
I have oncemore issue with my OH2.5.3-1 and NG Rules.
I only want to swich of my Poer TP-Link HS110 pluf, whenthe power on the plug is less than 5W
It has work a couple of while, and other same feature like this work, e.g. for switch off my power supply from me mobile. Now the same pricip is not working anymore.
The trick with the “” for having not in the rule for e.g. 5.0 and “5.0” I already checked. butit is not working as it should be.
Has someone any idea?
Here is a snapshot from rule:
“ecec9ea8-ed0c-4334-92ea-fc464ca9718a”: {
“class”: “org.openhab.core.automation.dto.RuleDTO”,
“value”: {
“triggers”: [
“id”: “4”,
“label”: “an item state is updated”,
“description”: “This triggers the rule if an item state is updated (even if it does not change).”,
“configuration”: {
“itemName”: “BRoKellerFahrradladegerT_Power”
“type”: “core.ItemStateUpdateTrigger”
“conditions”: [
“inputs”: {},
“id”: “5”,
“label”: “an item has a given state”,
“description”: “Compares the item state with the given value”,
“configuration”: {
“itemName”: “BRoKellerFahrradladegerT_Power”,
“state”: 5.0,
“operator”: “\u003c”
“type”: “core.ItemStateCondition”
“inputs”: {},
“id”: “6”,
“configuration”: {
“itemName”: “tplinksmarthome_hs110_911088_power”,
“state”: 0.0,
“operator”: “!\u003d”
“actions”: [
“inputs”: {},
“id”: “2”,
“label”: “send a command”,
“description”: “Sends a command to a specified item.”,
“configuration”: {
“itemName”: “BRoKellerFahrradladegerT_Betrieb”,
“command”: “OFF”
“type”: “core.ItemCommandAction”
“configuration”: {},
“configDescriptions”: [],
“uid”: “ecec9ea8-ed0c-4334-92ea-fc464ca9718a”,
“name”: “Fahrradnetzteil zum Aufladen automatisch abschalten”,
“tags”: [],
“visibility”: “VISIBLE”,
“description”: “Fahrradnetzteil zum Aufladen automatisch abschalten”
Also some log file:
2020-04-07 15:55:42.955 [nt.ItemStatePredictedEvent] - BRoKellerFahrradladegerT_Betrieb predicted to become OFF
2020-04-07 15:55:42.974 [vent.ItemStateChangedEvent] - BRoKellerFahrradladegerT_Betrieb changed from ON to OFF
2020-04-07 15:55:43.128 [vent.ItemStateChangedEvent] - BRoKellerFahrradladegerT_Signal changed from -52 dBm to -51 dBm
2020-04-07 15:55:43.132 [vent.ItemStateChangedEvent] - BRoKellerFahrradladegerT_Power changed from 0.538444 W to 0.526244 W
2020-04-07 15:55:43.141 [vent.ItemStateChangedEvent] - BRoKellerFahrradladegerT_Current changed from 0.075406 A to 0.075005 A
2020-04-07 15:55:43.144 [vent.ItemStateChangedEvent] - BRoKellerFahrradladegerT_Voltage changed from 235.239735 V to 235.022788 V
2020-04-07 15:55:44.078 [ome.event.ItemCommandEvent] - Item ‘BRoKellerFahrradladegerT_Betrieb’ received command ON
2020-04-07 15:55:44.094 [nt.ItemStatePredictedEvent] - BRoKellerFahrradladegerT_Betrieb predicted to become ON
2020-04-07 15:55:44.121 [vent.ItemStateChangedEvent] - BRoKellerFahrradladegerT_Betrieb changed from OFF to ON
2020-04-07 15:55:44.426 [ome.event.ItemCommandEvent] - Item ‘BRoKellerFahrradladegerT_Betrieb’ received command OFF
2020-04-07 15:55:44.437 [nt.ItemStatePredictedEvent] - BRoKellerFahrradladegerT_Betrieb predicted to become OFF
2020-04-07 15:55:44.451 [vent.ItemStateChangedEvent] - BRoKellerFahrradladegerT_Betrieb changed from ON to OFF
2020-04-07 15:56:12.177 [ome.event.ItemCommandEvent] - Item ‘BRoKellerFahrradladegerT_Betrieb’ received command ON
2020-04-07 15:56:12.194 [nt.ItemStatePredictedEvent] - BRoKellerFahrradladegerT_Betrieb predicted to become ON
2020-04-07 15:56:12.222 [vent.ItemStateChangedEvent] - BRoKellerFahrradladegerT_Betrieb changed from OFF to ON
2020-04-07 15:56:13.154 [vent.ItemStateChangedEvent] - BRoKellerFahrradladegerT_Power changed from 0.526244 W to 0.0 W
2020-04-07 15:56:13.163 [vent.ItemStateChangedEvent] - BRoKellerFahrradladegerT_Current changed from 0.075005 A to 0.013613 A
2020-04-07 15:56:13.175 [vent.ItemStateChangedEvent] - BRoKellerFahrradladegerT_Voltage changed from 235.022788 V to 234.482431 V
2020-04-07 15:56:18.203 [ome.event.ItemCommandEvent] - Item ‘BRoKellerFahrradladegerT_Betrieb’ received command OFF
2020-04-07 15:56:18.216 [nt.ItemStatePredictedEvent] - BRoKellerFahrradladegerT_Betrieb predicted to become OFF
2020-04-07 15:56:18.234 [vent.ItemStateChangedEvent] - BRoKellerFahrradladegerT_Betrieb changed from ON to OFF
