Hello, I am using OpenHAB (1.8, because I have some restriction with the version to use).
I would like to read from a file but I cannot do it with a rule (I need to set some global variables).
var String url = "C:\\Users\\ago\\Documents\\Ruscio\\OpenHAB\\configurations\\high_level_goals.conf"
var String electricity_goal = null
var Number threshold //if goal is of temperature
var Date date_beg = null
var Date date_end = null
rule Startup
System started
var String lastGoal = null
logDebug( "mylogs", "Starting decision.rules...." )
var List<String> lines = new FileReader(url).readLines.map [ s |
logDebug( "mylogs", s)
if(s.equals("WINDOW") || s.contains("KEEP") || s.contains("ELEC")) {
lastGoal = s
else {
if(lastGoal.equals("WINDOW")) {
if(date_beg == null) {
date_beg = new SimpleDateFormat("HH:mm").parse(s)
} else {
date_end = new SimpleDateFormat("HH:mm").parse(s)
else if(lastGoal.contains("KEEP")) {
threshold = Float.parseFloat(s)
logDebug( "mylogs", lastGoal )
I am on Windows 10 and I am very confused on the syntax to be used, because it seems I cannot use Java to read files nor Xtend. In fact, this code does not work:
var String url = 'high_level_goals.conf'
var Timer windowsAlarm = null
rule Startup
System started
lastGoal = s
else {
} else {
Could you help me reading a file from rules? Thank you a lot in advance!
P.S.: file is there and it seems OH can find it
