Nobody knew you were using that code.
We can only go on what you tell us, in this case “the rule runs over 20 minutes”.
It would clarify the issues we’re talking about to look at why that’s not quite true.
The example rule triggers, creates a timer, and finishes in a few milliseconds.
That will queue for, use, and then release a “rules” thread.
The pending timer is scheduled for a future time and left in the care of the timer manager. No thread is used while timing.
At the appointed time, the timer’s execution block queues for one of the manager’s threads, then begins executing. There is nothing unpleasant in the example’s code, again this will be over in a few milliseconds, and the timer thread released.
Of course, part of the execution block was to reschedule itself for another future time, so round we go again.
In terms of threads, we need a normal rules thread just to begin the process, then a timer thread repeatedly for each dimming-step timer run.
There is an omission in the example, declaring a global variable to hold the timer handle. How did you fix that? I have a little worry that your version is spawning many timers.
Bear in mind we can’t see your rule variant, can’t see any logging it produces, can’t see the events in your events.log that you expect to trigger it, unless you show us.
Thanks for the detailed reply and I apologize if that sounded snarky - that wasn’t the intent. My point was that I didn’t see anything in the comments that would discourage me from using the code, and in testing it works fine, as long as I only run it that one time. When it is supposed to run the next morning, I don’t even get a log entry that it was triggered.
I am unsure about the issue with the global variable that needs to be fixed…sorry. I just copied the script, tested to see that it worked and moved on, only to find it wouldn’t work the next day. Not sure what I need to do here.
My rule is exactly the same, other than item names. The V_WakeUpSwitch is set to ON by a CRON rule in a different script.
Ahh, yes. I’m sorry… I didn’t realize I didn’t copy those over with the rest of the code. Rushing and I’ve been fighting with a Catalina issue with Apple at the same time. Super frustrating!
I moved the code into a different rules file and have triggered it successfully three times in a row (changing the reschedule to 5 seconds from 60).
My gut is that it doesn’t have to do with the code, but with something in the guts of the OH code and filesystem, but I clearly could be wrong.
I have another way of achieving the same results if using a different file doesn’t work tomorrow morning, but I prefer to use other peoples tried and true code instead of creating it myself.
Thanks for everyone’s processor cycles trying to help me out!
It’s fine, really It’s just that when you follow an issue with an idea about where the problem lies, it still pays to share apparently irrelevant details and clues for the extra pair of eyes. Different people’s experiences lead them to consider things you might not have.
Don’t see any problems with this rule and global variables by the way.
Can you actually see that happening in your events.log at the appropriate time?
I’m guessing that you do not see the “Parent WakeUp started” message in openhab.log
When it doesn’t work, I do not see that log. When I re-save the file and re-trigger the rule, I do.
I moved the rule into a different file and, without re-saving, ran it three consecutive times triggering it manually (a switch sends the ON command to the triggering item) and then two consecutive times triggering by a CRON job at a certain minute.
The other rules file has another copy of this rule, with the global variables re-named to match it, and a couple other innocent rules (if item change item - no timers, etc.)
This has not been my behavior with the other rules file, unless something happens overnight to disrupt the file.
I’m going to have these two rules run in the AM and see which, if either, fail.
Thanks again… dedicated testing time is hard, which makes all of this more frustrating…
Careful when copy pasting rules around. Every rule must have a unique name. System wide unique, not just in that file. (or they don’t work)
EDIT - snap!
Possibly the issue! There were two rules in the file with the same name, but in my test both rules ‘worked’ (could be coincidence). Just did a system-wide audit to fix, but these were the only ones.
Trust me, only one worked at a time - after any given reload. Last one to load wins. You might begin to see how editing a rules file might magically bring a rule back to life.
The text strings don’t look like they need to be unique:
as the logs don’t report issues when saved
as VSC does not indicate duplicates like it does with item names
as item labels (the main string I regularly interact with) does not have to be unique
it looks like it is just a helpful string for the logs
But it makes sense and is in the docs, and I’m appreciative of everyone for the help. If you can help with my Catalina problem that Apple Engineering is yet to solve, let me know!
