Don’t get me wrong. I’m not saying that my other rules do not stop. Just that last time it happens, it were the time based rules. Nevertheless also other rules do stop. But I don’t know when it happens and if all rules are stopping at the same time. If the rules stop, I also need to restart OH.
I just set the rule runtime to debug, so that at least I have a little insight, what happens.
@Kai will probably clarify what he meant, but my guess is that he meant the issue was created for the wrong repository. The rule engine is in the Eclipse SmartHome codebase but the issue was created in openhab-core.
Yes right.
And my second statement meant that an issue saying “rules stop working” won’t really help if there is no way to reproduce it in any way. The only report with a reproducible scenario is eclipse/smarthome#3132, which has been fixed - so my hope would be that your problem has the same root cause and thus will be fixed with this as well. So please try the very latest OH distro snapshot and see if it helps.
@bbubbat I can’t definitively lock it down to cron rules. I have a cron rule that runes every 10 minutes so there is always one relatively close to it stopping. Especially because my rules aren’t overly busy.
I can see in at least one case, the mentioned script fires at say 7:20, then at 7:30 and then 7:40 it doesn’t fire but at 7:46 a different (non-cron) rule does fire as the last rule to fire.
I already have esh-model-rule-runtime as well as esh-model-script-runtime set as debug. They don’t offer that much more.
@Kai, thanks! I try to avoid snapshots but I’ll have to look into switching from stable. I fully get the need to reproduce… I just can’t find anything other than time that does it.
I looked at my cron and it does have a “?” but it seems in that issue they were having trouble with specific day of week? I don’t fully follow what they are saying.
@Kai I use the latest official docker 2.1.0-SNAPSHOT published two days ago. So I assume that the changes are already in it. All eclipse smart home bundles do have the version number 0.9.0.201703131829
Do you know how I can trace the problem? Which packages should I set to debug?
I’d like to ask @kgoderis for help as he has implemented the CRON library - he should be the best person to tell, what might be wrong or how to best debug it.
Time cron "0 0 23 * * ?"
Time cron "0 0 5 * * ?"
Time cron "0 0 7,22 * * ?"
Time cron "0 */10 15-22 * * ?"
Time cron "0 10 23 * * ?"
Time cron "0 */10 * * * ?"
Time cron "0 */30 * * * ?"
Time cron "0 0 6 ? * 1"
Time cron "0 0 21 ? * 1"
Time cron "0 45 5 ? * MON-FRI"
Time cron "0 0 15 ? * MON-FRI"
Time cron "0 30 7 ? * 7"
Time cron "0 30 21 * * ?"
Time cron "0 0 0 * * ?"
Time cron “25 0/5 * * * ?”
Sorry, there were more than I anticipated… The only one that I have seen around a lockup was the Time cron “0 */10 * * * ?” BUT, that doesn’t mean one of the other ones wasn’t doing something in the background.
If you want the full output with respect to the scheduling of the cron expressions, then the best thing you can do is to start up the runtime in debug modus, connect to the console (via ssh) and issue
I appreciate it. They all worked fine in OH 1. I pretty much pulled the includes out of the rules files and dumped them on my OH2 vm. NOW, I’m still on stable. Would some of these rules fail if I was on stable?
I have upped the log level.
Edit: I watched when my 10 minute cron hit and I didn’t see anything new logged. Just a DEBUG from runtime.internal.engine.executerulejob that I have been getting all along. Is this to be expected?
@kgoderis@Kai Right now no rule is working. Even though I get a trace output from my first cron rule
18:44:00.215 [TRACE] [cheduler.ExpressionThreadPoolManager] - Expression's '0 * * * * ?' next execution time is 2017-03-15 18:45:00.000
18:44:00.215 [TRACE] [cheduler.ExpressionThreadPoolManager] - Scheduling the task 'org.eclipse.smarthome.core.persistence.internal.PersistItemsJob@6a358e75' to execute in 59880 ms
18:44:00.216 [TRACE] [cheduler.ExpressionThreadPoolManager] - Task 'org.eclipse.smarthome.core.persistence.internal.PersistItemsJob@6a358e75' has now 1 Futures
18:44:00.216 [TRACE] [cheduler.ExpressionThreadPoolManager] - Putting the monitor thread 'ESH-persist-Monitor-1' to sleep for 59880 ms
So the scheduler seems to be working, but not the rules at all.
After restarting the docker container the rules seem to be up and working.
The weird thing is I do get the following output every minute:
19:06:00.402 [TRACE] [rthome.core.scheduler.CronExpression] - Expanded to 2 candidates
19:06:00.403 [TRACE] [rthome.core.scheduler.CronExpression] - Candidate 0 is 2017-03-15 19:06:00.000
19:06:00.403 [TRACE] [rthome.core.scheduler.CronExpression] - Candidate 1 is 2017-03-15 19:07:00.000
19:06:00.404 [TRACE] [rthome.core.scheduler.CronExpression] - Final candidate 0 is 2017-03-15 19:07:00.000
19:06:00.405 [TRACE] [cheduler.ExpressionThreadPoolManager] - Expression's '0 * * * * ?' next execution time is 2017-03-15 19:07:00.000
19:06:00.406 [TRACE] [cheduler.ExpressionThreadPoolManager] - Scheduling the task 'org.eclipse.smarthome.core.persistence.internal.PersistItemsJob@372f925a' to execute in 59833 ms
19:06:00.408 [TRACE] [cheduler.ExpressionThreadPoolManager] - Task 'org.eclipse.smarthome.core.persistence.internal.PersistItemsJob@372f925a' has now 1 Futures
19:06:00.409 [TRACE] [cheduler.ExpressionThreadPoolManager] - Putting the monitor thread 'ESH-persist-Monitor-1' to sleep for 59833 ms
which I guess is related to my first cron rule. But I don’t get any TRACE output from my ping cron rule. Just
