Whenever I restart openHAB, my rule that responds to changes in the DSC alarm fires as though it has received an update from the panel. It hasn’t, it’s just getting updated as the persistence restores the existing value.
Is there any wa of preventing this from happening. Apart from not persisting that item?
When the DSC Alarm binding initially connects to the alarm system it sends a Status Report command (001) to get status information on things like partitions and zones. This is probably what your rule is responding to when you restart openHAB. I’m not sure how you can avoid that in the rule.
Following on what @steve1 is saying here are the rules I use to send me emails when the partition arms and disarms:
rule "Partition1Armed"
Item PARTITION1_ARMED changed from OFF to ON
emailMessage = "DSC Alarm Stystem Armed\n\nPartition 1 has been armed."
sendMail(emailTo,emailSubject,emailMessage)
rule "Partition1Disarmed"
Item PARTITION1_ARMED changed from ON to OFF
emailMessage = "DSC Alarm Stystem Disarmed\n\nPartition 1 has been disarmed."
Yeah thanks @rsstephens and @steve1 , it looks like I need to change the trigger for this. I’ll try using PARTITION1_ARMED as the trigger, and then perform the if checks on PARTITION1_ARM_MODE afterwards.
Which will mean splitting it into two rules instead of one. One for ‘arming’ and one for ‘disarming’.
At the moment I’m just checking for a change of PARTITION1_ARM_MODE and then matching the different arm/disarm states to do different things.
rule "Alarm State Change Lighting Actions"
Item PARTITION1_ARM_MODE changed
if(PARTITION1_ARM_MODE.state == 0) {
if(PARTITION1_ARM_MODE.state == 1) {
I tried changing the settings in openhab.cfg as @unixhaj suggested, but it still behaves the same.
EDIT:
I’d like to perform different actions on the event of a ‘disarm’ happening. If it’s from an ‘away’ arming, and it’s not daylight, I’d like to switch the lights on. If it’s from a ‘stay’ arming, it might be because my child has woken in the night and we’ve come downstairs to the kitchen for some medicine, so I don’t really want all the the light to go on throughout the house… waking everyone else up! Can I access the previousState for a different item than the one I’m using? i.e could I reference the previousState of PARTITION1_ARM_MODE when triggered by PARTITION1_ARMED?
Or maybe I could capture the ‘arm mode’ of the alarm in a variable before it gets changed by the disarming?
I’ve changed to using Item PARTITION1_ARMED instead, and it seems to prevent the rule being triggered on startup. I had to re-jig things a little bit to split them into two rules, but that has other advantages for other things, so that’s a plus too.
Now I’ve got:
java
rule "Alarm Disarm Lighting Actions"
when Item PARTITION1_ARMED changed from ON to OFF
logInfo("Alarm","Partition Disarmed")
val message = "The alarm is now\n\nDisarmed and is ready\n\nRegards,\n\nopenHab"
sendMail(mailTo, "Alarm Disarmed", message)
if(daylight.state == OFF) {
logInfo("Alarm","It's dark outside so lights to normal")
normal.members.forEach[light | // for each light
light.sendCommand(ON)
logInfo("Alarm","Lights to Normal Commands Sent")]
else {
logInfo("Alarm","It's daylight. So we do nothing.") }
rule "Alarm Arm Lighting Actions"
when Item PARTITION1_ARMED changed from OFF to ON or
Item Light_Test changed
logInfo("Alarm","Partition Armed AWAY")
val message = "The alarm is now\n\nArmed Away\n\nRegards,\n\nopenHab"
sendMail(mailTo, "Alarm ARMED Away", message)
logInfo("Alarm","The house is empty, all lights off in 10 seconds...")
waitTimer3 = createTimer(now.plusSeconds(10), [|
allLights.members.forEach[light | // for each light
light.sendCommand(OFF) ]]
logInfo("Alarm","ALL Lights OFF Commands Sent")
... and so on...
Just for the record… I’ve had to introduce a ‘wait’ after the "Alarm Arm Lighting Actions" rule gets triggered as it seemed openHAB wasn’t getting the update to the PARTITION1_ARM_MODE immediately and so would not do anything 50% of the time. And I removed the if(PARTITION1_ARM_MODE.state == 0) as it was redundant.
So it’s now all working very smoothly and as expected!
java
if(morning.state == OFF) {
logInfo("Alarm","Lights to Normal Command Sent")]
else {
logInfo("Alarm","It's morning. So we do nothing.")
logInfo("Alarm","Partition Armed, waiting for state to update...")
armTimer = createTimer(now.plusSeconds(2), [|
logInfo("Alarm","The house is empty, all lights off in 2 seconds...")
waitTimer3 = createTimer(now.plusSeconds(2), [|
if(PARTITION1_ARM_MODE.state == 2) {
logInfo("Alarm","Partition Armed STAY")
val message = "The alarm is now\n\nArmed Stay\n\nRegards,\n\nopenHab"
sendMail(mailTo, "Alarm ARMED Stay", message)
logInfo("Alarm","Everyone's in bed, lights out in 2 seconds...")
waitTimer4 = createTimer(now.plusSeconds(2), [|
night.members.forEach[light | // for each light
logInfo("Alarm","Nightime lighting Commands Sent")
if(PARTITION1_ARM_MODE.state == 3) {
logInfo("Alarm","Partition Armed AWAY no delay. Not sure what this is.")
sendMail(mailTo, "Alarm ARMED Away no delay", message)
if(PARTITION1_ARM_MODE.state == 4) {
logInfo("Alarm","Partition Armed STAY no delay. Not sure what this is.")
sendMail(mailTo, "Alarm ARMED Stay no delay", message)
