If I want to use the timer datatype to run a command every X seconds, how do I do that?
The reason I don’t want to use cron is because it has to start on an activity.
rule "start cycle"
Item cycle_start_PB received update
waitTimer = createTimer(now.plusSeconds(5))[|
say("five seconds")
waitTimer = createTimer(now.plusSeconds(5)) //this line does not work
I’d like the timer to restart after it runs. So I should here “five seconds”…“five seconds”…“five seconds”… forever, until I explicitely null out the timer somehow.
I know I can use cron with some if statements to kind of prevent the execution…
rule "repeat every 5 seconds kind of"
Time cron "0 0/5 * * * ?"
if ( put flags here )...
But it doesn’t work well for some specific things I’m trying to do.
Instead of creating a new timer, try rescheduling it.
waitTimer.reschedule (now.plusSeconds (5))
You may need to make sure I got the function name right. I’m going from memory and it may be something like rescheduleTimer.
The problem is the createTimer inside the timer creates a timer that doesn’t do anything but to create a timer that does the same thing puts you into a situation where you get stuck in an infinite repetition. Kind of like facing two mirrors at each other.
you kick off the timers by switching switch 1 on
switch 1 triggers a rule that starts timer 1 which, after 5 seconds, turns switch 1 off and switch 2 on
switch 2 triggers a rule that starts timer 2 which, after 5 seconds, turn switch 1 off and switch 2 on
