Good morning from Slovakia,
I am trying to implement opening up the Ikea Tradfri blinds depending on sun angle.
How can I run it only once a day?
rule "uhol_slnka_rolety"
//zahrnut teplotu von/dnu a svetlo - meteostanica
Item LocalSun_Azimuth changed
if (LocalSun_Azimuth.state > 175| "°" && LocalSun_Azimuth.state < 178| "°") { //Juzne okna su 197deg. dat toleranciu 3stupne
sendBroadcastNotification("Utekaj pozriet, ci uz je tien")
logInfo("uhol_slnka_rolety.rules", "Sunblinds up when azimuth exceeds treshold" )
I tried it to run it only when sun is between 175 and 178 degrees, but sometimes it is running twice. I know I can tune it up with changing the Item interval (currently 300 sec), but I suppose it is not the greatest way how to do it…
It is currently in testing, I am trying to figure out the sun angle, so there is no sunblinds command actually.
hi there, why dont you use a bool, and set it true when blinds are operated? and set it false at midnight. then „ if bool = true and angle = xyz then …“
if (Tradfri blinds.state == 100) { return; } // the 100 is just an example for the full up state of your blind.
The rule won´t continue to your current IF in case the blind is already up or was never down that day or put up manually before
You could consider to add Time of Day pattern to it so that the rule in generally only runs like in the afternoon and not every time LocalSun_Azimuth changes, which i suspect happens all day, right?
And all night but running a rule doesn’t cost much, simplicity is good.
I think the trouble with basing a “do it” decision on existing state is that you won’t get the “once a day” effect. If someone manually closes the blinds, the rule may come along and open them again because it doesn’t know it’s already done it that day.
That´s correct. If i interpret the intention of @misko903 correctly, he wants the blinds that “potentially” are down go up based on the state of the sun in a short window of time. If yes, in my view he could even leave this rule as is and not worry the rule eventually fires 2 times during 175 - 178. the worse that happens is 2 log entries. If the blind get´s another command up and is already up, who cares… The compexity would start if the blinds go up, someone intentionally put them down again for whatever reason if still between 175-178 and a minute later or so it goes up again…, still in 175 - 178. Correct?
I think the best solution would be to set the boolean to true, which will be reset on midnight.
This is what I am going to test now:
var boolean roletyIsliHore = true
if (LocalSun_Azimuth.state > 175| "°" && roletyIsliHore == false) { //Juzne okna su 197deg.
// if (Sunblinds.state != UP) {sendCommand(Sunblinds, UP)}
//nastavit roletyIsliHore = false o polnoci
rule "polnocny_reset_roletyIsliHore"
Time is midnight
does not worked, the command comed up at midnight, as roletyIsliHore is reset to false
and LocalSun_Azimuth.state > 175| "°" && roletyIsliHore == false
Is anyone guys using the blinds same way?
I want the blinds to stop the sun heating the house in summer.
My first idea is to measure temp outside, and when it is probabilty to heat the house, the blinds will be closed.
other than that, I want to have a nice view and blinds will be opened on the sunrise.
do you have another idea what to take into account? cloud coverage is not very good in our hilly country.
like this? if (LocalSun_Azimuth.state > 175| "°" && LocalSun_Azimuth.state < 178| "°" && roletyIsliHore == false)
honestly, I thought about it, but i was afraid that there can be value lower and higher and then the rule is not triggered at all. But wait, I can open the interval more! if (LocalSun_Azimuth.state > 175| "°" && LocalSun_Azimuth.state < 190| "°" && roletyIsliHore == false)
I actually have something very similar - i partially close blinds if the sun is shining through the windows, mine looks like this:
rule "Stineni proti slunci"
Item virtual_sun_azimuth received update or
Item virtual_sunblock_toggle received command
var status = OFF
var noon_time = new DateTimeType(virtual_noon_end.state.toString)
var azimuth = (virtual_sun_azimuth.state as Number).doubleValue
var angle = (virtual_sun_angle.state as Number).doubleValue
var tempOut = if (balcony_temperature.state == NULL) 0 else (balcony_temperature.state as Number).intValue
var tempIn = if (livingroom_temperature.state == NULL) 0 else (livingroom_temperature.state as Number).intValue
logDebug("Sunblock", "Noon: " + noon_time + ", azimuth: " + azimuth + ", angle: " + angle + ", tempIn: " + tempIn + ", tempOut: " + tempOut)
if (virtual_sunblock_toggle.state == ON && virtual_day.state == ON && now.isAfter(noon_time.getZonedDateTime) && tempIn >= 23 && tempOut >= tempIn) {
// if sun > 57 deg - too high, not shining in
if(angle <= 55 && azimuth > 218) {
// under 270 - next to building, height doesn't matter
if(azimuth <= 270) {
status = ON
} else {
// above building but only until 27
if(angle >= 27) {
status = ON
if (virtual_sunblock_active.state != status) {
logInfo("Sunblock", status + " - Noon: " + noon_time + ", azimuth: " + azimuth + ", angle: " + angle + ", tempOut: " + tempOut + ", tempIn: " + tempIn)
virtual_sunblock_active.postUpdate(status)
And the rule that actually controls the blinds:
rule "Roleta obyvak - zatahnout proti slunci"
Item virtual_sunblock_active changed
if(virtual_sunblock_active.state == ON) {
if(livingroom_blinds.state < 40) {
livingroom_blinds.sendCommand(40)
} else {
if(livingroom_blinds.state == 40) {
livingroom_blinds.sendCommand(0)
What about the cloudiness? Did you thought about to integrate it? My idea is to do it so:
if there is a prediction of 30% cloudines until cca 13:00, the sunblinds will be open in the morning already. No matter the temperatures.
Yes I was thinking about it, but just weather prediction is not accurate enough for this kind of thing. I think it would need something like light sensor, but I didn’t found any which can measure direct sunlight. That rule with sun position and temperature seems to work good enough for me.
