Actually, I have the same issue. Did you find the culprit?
This is actually the only item which causes some issue. Not sure though what the impact is.
When I map the folders according best practice, but still using my old conf directory mapped, the system crashes immediately.
ExecStart=/usr/bin/docker run --name=%n --net=host \
-v /etc/localtime:/etc/localtime:ro \
-v /etc/timezone:/etc/timezone:ro \
-v /home/zotac/openhab2:/openhab/conf \
-v /opt/openhab/userdata:/openhab/userdata \
-v /opt/openhab/addons:/openhab/addons \
-v /opt/openhab/.java:/openhab/.java \
result:
2019-11-12 20:04:19.537 [ERROR] [org.apache.felix.scr ] - bundle org.apache.felix.scr:2.1.2 (39)Circular reference detected trying to get service {org.eclipse.smarthome.core.audio.AudioSink}={service.id=118, service.bundleid=116, service.scope=bundle, component.name=org.eclipse.smarthome.io.javasound.internal.JavaSoundAudioSink, component.id=6}
stack of references: ServiceReference: {org.eclipse.smarthome.core.audio.AudioSink}={service.id=118, service.bundleid=116, service.scope=bundle, component.name=org.eclipse.smarthome.io.javasound.internal.JavaSoundAudioSink, component.id=6}
ServiceReference: {org.eclipse.smarthome.core.audio.AudioManager, org.eclipse.smarthome.config.core.ConfigOptionProvider}={service.id=120, service.bundleid=103, service.scope=bundle, defaultSink=enhancedjavasound, service.config.label=Audio, component.name=org.eclipse.smarthome.core.audio.internal.AudioManagerImpl, component.id=7, service.config.category=system, felix.fileinstall.filename=file:/openhab/userdata/etc/org.eclipse.smarthome.audio.cfg, service.pid=org.eclipse.smarthome.audio, service.config.description.uri=system:audio}
Having my mapping as follows, and using the old userdata location,
-v /var/lib/openhab2:/openhab/userdata \
gets the system up and running, and as far as I can see it behaves normal. Only entries in the log files are:
2019-11-12 16:04:24.657 [ERROR] [org.apache.felix.fileinstall ] - Cannot create folder /var/lib/openhab2/tmp/bundles. Is the folder write-protected?
2019-11-12 16:04:24.666 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedServiceFactory, id=38, bundle=10/mvn:org.apache.felix/org.apache.felix.fileinstall/3.6.4]: Unexpected problem updating configuration org.apache.felix.fileinstall.098b1b9c-eaed-41c3-8fac-c8c88d5624c5
java.lang.RuntimeException: Cannot create folder: /var/lib/openhab2/tmp/bundles
Anyone, any idea?
