I am trying to store item states values into mapdb.
I am using eclipse smart home repo and org.openhab.persistence.mapdb.
Below following url to get eclipse smart home repository.
After getting the esh repo, we have to install cleanly by using " mvn clean install
Then put mapdb jar files into deploy folder.
When I was start the esh server, the mapdb throws a below error
18:31:42.317 DEBUG [FelixStartLevel] BundleEvent STARTING - org.openhab.persistence.mapdb
18:31:42.318 DEBUG [FelixStartLevel] MapDB persistence bundle has been started.
18:31:42.322 DEBUG [FelixStartLevel] BundleEvent STARTED - org.openhab.persistence.mapdb
18:31:42.333 DEBUG [FelixStartLevel] mapdb persistence service is being activated
18:31:42.568 ERROR [FelixStartLevel] [org.openhab.persistence.mapdb(181)] The activate method has thrown an exception
java.lang.RuntimeException: java.lang.ClassNotFoundException: org.openhab.persistence.mapdb.internal.MapDBitemSerializer
at org.mapdb.SerializerPojo.classForName(SerializerPojo.java:96) ~[?:?]
at org.mapdb.SerializerPojo.<init>(SerializerPojo.java:112) ~[?:?]
at org.mapdb.Store.getSerializerPojo(Store.java:113) ~[?:?]
at org.mapdb.EngineWrapper.getSerializerPojo(EngineWrapper.java:135) ~[?:?]
at org.mapdb.DB.<init>(DB.java:82) ~[?:?]
at org.mapdb.DBMaker.make(DBMaker.java:668) ~[?:?]
at org.openhab.persistence.mapdb.internal.MapDBPersistenceService.activate(MapDBPersistenceService.java:113) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:372) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:320) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:291) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.framework.EventDispatcher.invokeServiceListenerCallback(EventDispatcher.java:990) [?:?]
at org.apache.felix.framework.EventDispatcher.fireEventImmediately(EventDispatcher.java:838) [?:?]
at org.apache.felix.framework.EventDispatcher.fireServiceEvent(EventDispatcher.java:545) [?:?]
at org.apache.felix.framework.Felix.fireServiceEvent(Felix.java:4594) [?:?]
at org.apache.felix.framework.Felix.registerService(Felix.java:3586) [?:?]
at org.apache.felix.framework.BundleContextImpl.registerService(BundleContextImpl.java:348) [?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [46:org.apache.felix.scr:2.0.12]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
at org.apache.felix.framework.EventDispatcher.invokeBundleListenerCallback(EventDispatcher.java:915) [?:?]
at org.apache.felix.framework.EventDispatcher.fireEventImmediately(EventDispatcher.java:834) [?:?]
at org.apache.felix.framework.EventDispatcher.fireBundleEvent(EventDispatcher.java:516) [?:?]
at org.apache.felix.framework.Felix.fireBundleEvent(Felix.java:4578) [?:?]
at org.apache.felix.framework.Felix.startBundle(Felix.java:2173) [?:?]
at org.apache.felix.framework.Felix.setActiveStartLevel(Felix.java:1372) [?:?]
at org.apache.felix.framework.FrameworkStartLevelImpl.run(FrameworkStartLevelImpl.java:308) [?:?]
at java.lang.Thread.run(Thread.java:745) [?:?]
Caused by: java.lang.ClassNotFoundException: org.openhab.persistence.mapdb.internal.MapDBitemSerializer
at java.net.URLClassLoader.findClass(URLClassLoader.java:381) ~[?:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:424) ~[?:?]
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331) ~[?:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:?]
at java.lang.Class.forName0(Native Method) ~[?:?]
at java.lang.Class.forName(Class.java:348) ~[?:?]
at org.mapdb.SerializerPojo.classForName(SerializerPojo.java:94) ~[?:?]
... 73 more
18:31:42.583 ERROR [FelixDispatchQueue] FrameworkEvent ERROR - org.openhab.core.compat1x
org.osgi.framework.ServiceException: Service factory returned null. (Component: org.openhab.persistence.mapdb (181))
at org.apache.felix.framework.ServiceRegistrationImpl.getFactoryUnchecked(ServiceRegistrationImpl.java:380) ~[?:?]
at org.apache.felix.framework.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:247) ~[?:?]
at org.apache.felix.framework.ServiceRegistry.getService(ServiceRegistry.java:350) ~[?:?]
at org.apache.felix.framework.Felix.getService(Felix.java:3736) ~[?:?]
at org.apache.felix.framework.BundleContextImpl.getService(BundleContextImpl.java:470) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:72) ~[?:?]
at org.apache.felix.scr.impl.inject.BindMethod.getServiceObject(BindMethod.java:651) ~[?:?]
at
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) ~[?:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) ~[?:?]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) ~[?:?]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
at org.apache.felix.framework.EventDispatcher.invokeBundleListenerCallback(EventDispatcher.java:915) ~[?:?]
at org.apache.felix.framework.EventDispatcher.fireEventImmediately(EventDispatcher.java:834) ~[?:?]
at org.apache.felix.framework.EventDispatcher.fireBundleEvent(EventDispatcher.java:516) ~[?:?]
at org.apache.felix.framework.Felix.fireBundleEvent(Felix.java:4578) ~[?:?]
at org.apache.felix.framework.Felix.startBundle(Felix.java:2173) ~[?:?]
at org.apache.felix.framework.Felix.setActiveStartLevel(Felix.java:1372) ~[?:?]
at org.apache.felix.framework.FrameworkStartLevelImpl.run(FrameworkStartLevelImpl.java:308) ~[?:?]
18:31:42.583 DEBUG [FelixStartLevel] mapdb persistence service is being activated
18:31:42.769 ERROR [FelixStartLevel] [org.openhab.persistence.mapdb(181)] The activate method has thrown an exception
at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) ~[46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) ~[46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) ~[46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:307) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:299) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:298) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) [46:org.apache.felix.scr:2.0.12]
at org.apache.felix.framework.ServiceRegistrationImpl.getFactoryUnchecked(ServiceRegistrationImpl.java:347) [?:?]
at org.apache.felix.framework.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:247) [?:?]
at org.apache.felix.framework.ServiceRegistry.getService(ServiceRegistry.java:350) [?:?]
at org.apache.felix.framework.Felix.getService(Felix.java:3736) [?:?]
at org.apache.felix.framework.BundleContextImpl.getService(BundleContextImpl.java:470) [?:?]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [11:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
... 65 more
18:31:42.776 ERROR [FelixDispatchQueue] FrameworkEvent ERROR - com.eclipsesource.jaxrs.publisher
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) ~[?:?]
at org.apache.felix.framework.EventDispatcher.invokeServiceListenerCallback(EventDispatcher.java:990) ~[?:?]
at org.apache.felix.framework.EventDispatcher.fireEventImmediately(EventDispatcher.java:838) ~[?:?]
at org.apache.felix.framework.EventDispatcher.fireServiceEvent(EventDispatcher.java:545) ~[?:?]
at org.apache.felix.framework.Felix.fireServiceEvent(Felix.java:4594) ~[?:?]
at org.apache.felix.framework.Felix.registerService(Felix.java:3586) ~[?:?]
at org.apache.felix.framework.BundleContextImpl.registerService(BundleContextImpl.java:348) ~[?:?]
18:31:42.778 DEBUG [FelixStartLevel] ServiceEvent REGISTERED - [org.openhab.core.persistence.PersistenceService] - org.openhab.persistence.mapdb
18:31:42.788 DEBUG [FelixStartLevel] mapdb persistence service is being activated
18:31:42.995 ERROR [FelixStartLevel] [org.openhab.persistence.mapdb(181)] The activate method has thrown an exception
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:749) [46:org.apache.felix.scr:2.0.12]
How to resolve this issue?
Thanks and Regards,
Amar.
