I have a Russound MCA C5 and I am setting up a sitemap.
I have issues figuring out what item is used to set the tuner radio station. I have the source switching working fine. My source 1 is the tuner, but I cannot for the life of me figure out the item name for the current radio station or how to change radio stations.
If anyone could please help that would be great. @tmrobert8
Thatâs a much harder question than you would expect. First off - do you use habpanel by any chance (I have a nice widget for habpanel that mimics the myrussound app interface - including doing what you are asking).
You might want to do some light reading on the underlying protocol (https://russound.com/document-center/search-result?filter_search=rio) to understand. Basically a zone has a source and that source can be different things - so to âcontrolâ the source, you send keystrokes to the zone as if you were working with a keypad. In your case, your source is a tuner - so to change channels, youâd need to send the radio station to the source as a series of keystrokesâŠ
Example - you need to send âKeyRelease DigitOneâ (case sensitive) to the âeventâ channel on the zone to have a â1â sent to the source. So if you try to tune to â105.1â - youâd send âKeyRelease DigitOneâ then âKeyRelease DigitZeroâ then âKeyRelease DigitFiveâ then âKeyRelease DigitOneâ to the âeventâ channel (note: there is a âkeyreleaseâ channel as well - just send âDigitxxxâ to it as an alternative).
This was from a private message but Iâm responding in public in case someone has the same question. Similar to the above - you need to send a ârestorePreset xâ to the âeventâ channel where x is the preset in question. Please note that the preset number ranges from 1 to 36 - 1-6 is the presets for bank 1, 7-12 is the presets for bank 2, etc
The second post was exactly what I was looking for. I did Wade through the code but the ârestorePresetâ wording had me questioning if I was looking at the right area.
This response was perfect and I can get the rest of what I need done with rules.
