rlkoshak
(Rich Koshak)
January 18, 2017, 9:21pm
21
I see no reason why you would be getting that error. lastCount is defined as a var where it is supposed to be.
Try giving a hint by defining lastUpdate as an int.
var int lastUpdate = 0
Similarly give the same hint when you define newCommand:
var int newCommand = ...
The imports look OH for OH 1.8
Persistence would neither solve nor explain this problem.
halloween
(Hallo Ween)
January 18, 2017, 10:03pm
22
With this changes i get “pointer exception null …” very much lines of errors…
Has to do with lastUpdate i think.
When removing the “int” from lastUpdate, i get the single error like before… cannot resolve lastUpdate to item or type.
rlkoshak
(Rich Koshak)
January 18, 2017, 10:18pm
23
Does Designer highlight anything as an error?
halloween
(Hallo Ween)
January 18, 2017, 10:20pm
24
I don’t use it, have first to learn how to install it.
rlkoshak
(Rich Koshak)
January 18, 2017, 11:02pm
25
http://www.openhab.org/getting-started/downloads.html
Download the version for your OS. Press the folder icon in the upper left and select your configurations folder.
It won’t run on a Pi. If you are running on a Pi you need to share your /etc/openhab/configurations folder via samba or copy that folder to some other machine, edit it there, then copy the edits back over.
halloween
(Hallo Ween)
January 19, 2017, 6:51am
26
I did this yesterday - but i got warnings/errors on nearly each line.
So i renamend the rulefile to *.txt and will test it again, when i make the update to OH2. I will wait the few days until final release and then start from the beginning with a new installation.
Thanks for your help.
halloween
(Hallo Ween)
February 16, 2018, 10:14am
27
I tried to get this rule running again…
But i get an error, i hope, someone can help me?
The error is because of the variable “average”.
// Variablen Stromzähler Wärmepumpe
var lastUpdate = null
var lastCount = 0
var ticksBetween = 5
var smoothingSamples = 2
var total = 0.0d
var average = 0.0d
val samples = newLinkedList()
rule "Stromzaehler Waermepumpe Berechnung Watt"
Item HeatPump_Stromzaehler received command
logInfo("Stromzaehler Waermepumpe Berechnung Watt", "Stromzähler received Update")
* Take 2: React on every input, get the time inbetween and calculate power based
* on time passed.
* Very granular, calculation takes about 20ms on Raspi3B
var newCommand = (receivedCommand as DecimalType).intValue
var tickDiff = newCommand - lastCount
logInfo("Waermepumpe Berechnung Watt", "newCommand: " + newCommand)
logInfo("Waermepumpe Berechnung Watt", "tickDiff: " + tickDiff)
if (lastUpdate !== null && lastCount > 0) {
if (tickDiff == ticksBetween) {
var startMillis = now().millis
var nowMillis = now().millis
var lastUpdateMillis = (lastUpdate as DateTime).millis
var diff = nowMillis - lastUpdateMillis
var watt = ((1800.0 / diff) * 1000.0 * ticksBetween) as Double
logInfo("Waermepumpe Berechnung Watt", "startMillis: " + startMillis)
logInfo("Waermepumpe Berechnung Watt", "nowMillis: " + nowMillis)
logInfo("Waermepumpe Berechnung Watt", "lastUpdateMillis: " + lastUpdateMillis)
logInfo("Waermepumpe Berechnung Watt", "diff: " + diff)
logInfo("Waermepumpe Berechnung Watt", "watt: " + watt)
// Calculate moving average
if (samples.size == smoothingSamples) {
total -= (samples.first as Double).doubleValue
samples.removeFirst
total += watt
samples.addLast(watt)
average = total / samples.size
var endMillis = now().millis
logInfo("Stromzaehler Waermepumpe Berechnung Watt", "Timediff since last update: " + diff.toString() + " ms, posting average: " + average.toString() + " W, calculated "+ watt.toString() + " W")
logInfo("Stromzaehler Waermepumpe Berechnung Watt", "Calculation took " + (endMillis - startMillis).toString() + " ms")
logInfo("Waermepumpe Berechnung Watt", "average: " + average)
Heatpump_Stromzaehler_Watt.postUpdate(average)
else {
logInfo("Waermepumpe Berechnung Watt", "Tick difference not what we expected (" + ticksBetween + "): " + tickDiff)
lastUpdate = now()
lastCount = newCommand
Error:
2018-02-16 11:09:03.222 [INFO ] [l.script.Waermepumpe Berechnung Watt] - average: 22.164758034724787
2018-02-16 11:09:03.223 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Stromzaehler Waermepumpe Berechnung Watt': The name 'Heatpump_Stromzaehler_Watt' cannot be resolved to an item or type; line 51, column 4, length 26
item:
Number HeatPump_Stromzaehler_Watt "Wärmepumpe [%.3f kW]" <energy> //Calculated via rule
imhofa
(Andreas Imhof)
February 16, 2018, 11:30am
28
Typo (=Tippfehler)?
Your Item has an capital “Pump” and your rule uses lowercase “pump”…
andreas
halloween
(Hallo Ween)
February 17, 2018, 9:41am
29
This was it… Thanks! I looked into my rules-file and items-file many times, but i didn´t see the typo.
Rumen
(Rumen)
March 19, 2019, 2:06pm
30
I am using this one to monitor the whole house and it works great for me.
There are separate reports for instant power of each line in kW.
