I used the approach of burning a SD with Openhabian using Etcher, set up wifi, start the Pi and waited. Installation stopped, problems with apt or something like that. Used openhabian-config v1.4-372 and installed all under 60. Then in order: 10, 30 and 40 : all submenu’s. Apart from the cat /boot/log with the fail in their during startup of the putty my z-wave network is now added and more or less working.
I moved now to editing configuration with eclipse on my laptop, but hit a problem with samba. I have a laptop that is work related and defaults users in a domain called CS (Windows network at work). At home I’m not in that domain. I opened the raspberry pi in explorer using \192.168.xx.xx and \SmartHomePi and see the shares openHAB-conf and openHAB-share in both cases. When opening my credentials are requested. So I tried so far:
My passwords openhabian:openhabian and openhab:habopen
I tried as user:
CS\openhabian
\openhabian
WORKGROUP\openhabian
workgroup\openhabian
CS\openhab
\openhab
WORKGROUP\openhab
All give access denied or I end up in mulitple connections not allowed. In the latter case I rebooted my laptop complete and retried.
I’m completely lost and after 2 days deep digging the internet and fixing and adding more and more lib’s, rights and other ideas on samba I finally give up.
I did not change the smb.conf as it was part of Openhabian. Can anyone help me fix this? Please please anyone?
- Platform information:
- Hardware: Raspberry Pi 3/Thinkpad W540
- OS: Openhabian dd 23-02-2018/Windows 7 Professional SP1
- Java Runtime Environment: Zulu Embedded 8.25.0.76-linux-aarch32hf/Oracle java 8.121
- openHAB version: 2.2.0/NA
- Issue of the topic:
