[openhab2]
path = /opt/openhab2
available = yes
read only = no
browseable = yes
public = no
writeable = yes
force user = openhab
force group = openhab
create mask =0777
directory mask=0777
guest ok = no
I run OH2 an a odroid U3. I installed it as described in the manual.
As recommended, i tried to activate samba to work on the configuration via my windows machine.
something is not working with the network shares mapping on your Windows PC…
(by the way, I saw that you tried to map it to the Y:\ drive letter but the error is showing Z:\ )
Using google xlate, I see that you get an error of the following kind: “The local device is already being used” (der lokale gerätename wird bereits verwendet)
Check the following in a command line in your windows pc:
net use
and remove any existing network mappings from the drive letter that you are trying to use in advance:
