Samba is not appearing
I installed openhab2 on my raspberry pi.
I manually installed samba by
sudo openhabian-config
and select “Manual/Fresh Setup” Then
[ ] 66 | Samba                Install the Samba file sharing service and set up openHAB 2 shares
But is not appearing!
Can anyone help?
Can anyone help?!
Start with
sudo apt-get install samba samba-common-bin
Did you press Space to select Samba, then tab to Execute?
Do you have a display at least 120 characters wide, because if you don’t, you can’t select anything from this menu!
I tried this but NOT working!
Yes, I did everything but not working Also!
same here. No sign of the folders from Windows file explorer. :frowning:
It had previously worked fine the with Openhabian installation, so not sure where to look now?
Here is a quick tutorial which will help workshop.
