Gorhell
(Glenn Peñaverde)
January 25, 2019, 3:45pm
#1
Platform information:
Hardware: Rapsperry Pi 2 model B
OS: Raspbian latest
Java Runtime Environment: Java™ SE Runtime Environment (build 1.8.0_201-b09)
openHAB version: Openhab 2.4.0
Issue of the topic: I can’t see Samba in my Windows 10 PC. I set it up everything based on the documents
enable win support
my smb.conf file
[OpenHAB]
comment = OpenHAB
path = /usr/share/openhab2
create mask = 0777
directory mask = 0777
read only = No
[openHAB2-userdata]
comment = openHAB2 userdata
path = /var/lib/openhab2
create mask = 0777
read only = No
[openHAB2-conf]
comment = openHAB2 site configuration
path = /etc/openhab2
create mask = 0777
read only = No
No idea why it’s not showing up and how can i trouble shoot this
H102
(CM6.5 H102)
January 25, 2019, 3:58pm
#2
I’m using an RPI also and here’s a pic of my working samba config located at /etc/samba/smb.conf
mhilbush
(Mark)
January 25, 2019, 4:02pm
#3
H102:
I love that veto of .DS_Store files. I need to add that to my config!
H102
(CM6.5 H102)
January 25, 2019, 4:07pm
#4
Just trying to keep it clean. Glad you like it.
Gorhell
(Glenn Peñaverde)
January 25, 2019, 4:10pm
#5
Won’t allow me to connect.
Sorry I’m new to linux
H102
(CM6.5 H102)
January 25, 2019, 4:13pm
#6
What name are you using to access the samba share? The default name is openhabian and password is openhabian.
Gorhell
(Glenn Peñaverde)
January 25, 2019, 4:23pm
#7
I use my custom account and the default one. Still not working, funny thing is it’s not even showing in my network
It should show up here right?
H102
(CM6.5 H102)
January 25, 2019, 4:26pm
#8
At the moment I’m using linux mint and this is what it looks like.
Did you install OH using the openhabian image or do a manual install?
Gorhell
(Glenn Peñaverde)
January 25, 2019, 4:28pm
#9
I install it based on the package repo, I flash my sdcard with raspbian latest full and install the OH2 via putty using package repo then openhabian config tool. Also whe I hit the manual setup in openhabian tool and choose samba, nothing happens.
H102
(CM6.5 H102)
January 25, 2019, 4:35pm
#10
Have you changed the samba smb.conf to add browseable=Yes and writeable=Yes like in the pic I posted?
Per the doc’s your file should have this at minimal:
[openHAB2-userdata]
comment=openHAB2 userdata
path=/var/lib/openhab2
browseable=Yes
writeable=Yes
only guest=no
public=no
create mask=0777
directory mask=0777
[openHAB2-conf]
comment=openHAB2 site configuration
path=/etc/openhab2
browseable=Yes
writeable=Yes
only guest=no
public=no
create mask=0777
directory mask=0777
Gorhell
(Glenn Peñaverde)
January 25, 2019, 4:41pm
#11
Yes I edit my smb.conf to this
but when i do testparm it shows like this:
H102
(CM6.5 H102)
January 25, 2019, 4:47pm
#12
I only see openhab-userdata and openhab-conf are you missing the openhab-share and could that be the problem?
Under Custom Share Definitions add like below.
Gorhell
(Glenn Peñaverde)
January 25, 2019, 4:56pm
#13
I only have share definitions not the custom share definitions. As instructed in the docs I should put it in the end of the file right?
H102
(CM6.5 H102)
January 25, 2019, 5:02pm
#14
Yes, that should work as Custom Definitions are at the end of the file.
Gorhell
(Glenn Peñaverde)
January 25, 2019, 5:09pm
#15
Still same issue. can’t see it on windows network
H102
(CM6.5 H102)
January 25, 2019, 5:11pm
#16
After making changes did you try restarting samba? If not use sudo systemctl restart smbd.service
Also try with user name openhab instead of openhabian and see if that makes a difference.
Gorhell
(Glenn Peñaverde)
January 25, 2019, 5:16pm
#17
Still no signs of Samba in my windows network.
H102
(CM6.5 H102)
January 25, 2019, 5:21pm
#18
I have no idea how your network and PC is setup so I’m not sure what else to try. If you think it’s a problem with OH and not Windows then maybe try installing OH via the openhabian image.
https://bintray.com/openhab/bin/download_file?file_path=openhabianpi-raspbian-201804031720-gitdba76f6-crc9e93c3eb.img.xz
Installing this way samba should work out of the box without having to change or add anything on the OH/linux side.
H102
(CM6.5 H102)
January 25, 2019, 5:29pm
#19
You can also search the forum to see if there’s others with the same issue. Here is one topic I found but there are many more.
I have today the OpenHAbian on a Raspi 3B+.
It works fine, but I can’t access to the config-folder via samba share.
In the docu writes " If you are not able to connect, try with the IP of your device (e.g. smb://openhab@192.168.0.2 or \\192.168.0.2 )."
So I have tried to access from my file-explorer (client Windows 10) with \192.168.178.158 but my computer can’t connect to the server “… no folder found”
I have googled and found a solution, that I must activate SMB 1.0. I do it, but I…
Hope it helps.
mal
(Marco)
June 28, 2019, 8:15am
#20
Security over everything
If you’re on Windows 10 this should help:
Change Registry Value
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\LanmanWorkstation\Parameters\AllowInsecureGuestAuth
From 0 to 1
source:
https://support.microsoft.com/de-ch/help/4046019/guest-access-in-smb2-disabled-by-default-in-windows-10-and-windows-ser
