I am using openHAB2, and on my zwave network there are a total of 11 Qubino Flush Shutters (ZMNHCD1). When i check out the node xml, i found some differences between xmls, like:
node6.xml:
<nodeInformationFrame>
<commandClass>ZWAVE_PLUS_INFO</commandClass>
<commandClass>VERSION</commandClass>
<commandClass>MANUFACTURER_SPECIFIC</commandClass>
<commandClass>DEVICE_RESET_LOCALLY</commandClass>
<commandClass>POWERLEVEL</commandClass>
<commandClass>BASIC</commandClass>
<commandClass>SWITCH_ALL</commandClass>
<commandClass>SWITCH_BINARY</commandClass>
<commandClass>SWITCH_MULTILEVEL</commandClass>
<commandClass>METER</commandClass>
<commandClass>SENSOR_MULTILEVEL</commandClass>
<commandClass>MULTI_INSTANCE</commandClass>
<commandClass>ASSOCIATION</commandClass>
<commandClass>MULTI_INSTANCE_ASSOCIATION</commandClass>
<commandClass>ASSOCIATION_GROUP_INFO</commandClass>
<commandClass>CONFIGURATION</commandClass>
</nodeInformationFrame>
node9.xml:
As you can see, node 6 have an additional SENSOR_MULTILEVEL and MULTI_INSTANCE command classes even tough they are the exact same modules. And so i have some WARNs and ERRORs in my log file:
06:05:29.449 [WARN ] [.commandclass.ZWaveMeterCommandClass] - Unsupported Command 0x42 for command class METER (0x32).
06:05:29.969 [WARN ] [.commandclass.ZWaveMeterCommandClass] - Unsupported Command 0x42 for command class METER (0x32).
06:05:30.157 [WARN ] [.commandclass.ZWaveMeterCommandClass] - Unsupported Command 0x42 for command class METER (0x32).
06:05:30.336 [WARN ] [.commandclass.ZWaveMeterCommandClass] - Unsupported Command 0x42 for command class METER (0x32).
06:05:31.069 [WARN ] [.commandclass.ZWaveMeterCommandClass] - Unsupported Command 0x42 for command class METER (0x32).
08:52:44.135 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 6: Already processed another send data request for this callback Id, ignoring.
08:52:44.567 [ERROR] [tocol.commandclass.ZWaveCommandClass] - Error extracting value - length=9, offset=6, size=3.
11:53:08.750 [WARN ] [class.ZWaveMultiInstanceCommandClass] - NODE 6: The originating endpoint is 1. Please notify author.
11:53:08.751 [WARN ] [.commandclass.ZWaveMeterCommandClass] - Unsupported Command 0x00 for command class METER (0x32).
Should i copy the exact same xml from node9 to node6? Or any other solution?
Thanks…
