Samsung and Alarm Clock
Hi, Sending alarm clock time to opehnab from Samsung S24 with Android 15 seems not to be working. I check that for example sending battery level is working OK. Also sending alarm clock time from Oppo phone is working. It seems that the problem is with Samsung phone - does anyone has solution for this problem ?
Because Samsung doesn’t give you stock android it may be that it does alarm clock differently and the across app doesn’t know how to get it.
Also, iirc, the alarm time doesn’t get sent until moments before the alarm is scheduled.
