Hi
I have updated to openhab 4.0.4 but now the samsung pluging doenst working and see that only jar file is dor 4.1.0
Hi
There is some funky stuff going on with dependancy requirements for Openhab 4.1.
If you copy the 4.1.jar, and put it in the addons directory of Openhab 4.0, it won’t work. It is supposed to work if you install it via the marketplace.
If all of this fails, here is the 4.0 jar file (I know it says 4.1, but it works on 4.0).
still not working ever gone to older version openhab and still not working any ideas
Have you ever had the binding working? Did it stop working when you upgraded?
If you have never had it working, read the documentation, there are lots of reasons why it might not work.
yes was working before i updated as it api key for smarthing runing
Here are my TeamViewer ID number and connection password.
Please use them to start a remote support session with me.
TeamViewer ID: 1 331 347 462
Your password: pxwbje61
Not sure what that is a screen cap of,
Are you running OH 4.1? The 4.1 binding only works with OH4.1.
If you are running OH 4.0 or earlier, you need the earlier binding.
Problem is you haven’t even told me what version of Openhab you are running, so it’s hard to help.
For 4.0, you need the 4.0 binding (earlier will not work), for 4.1 you need the 4.1 binding (earlier will not work).
If you have OH 3.x, the 4.x binding will not work.
im running v4.00 becouse updated to 4.10 still had the problem
Then you need the V 1.16 binding I linked earlier.
Actually v1.15 should work as well.
Check the console and see what the status of the binding is. Do you have the UPNP transport installed?
Go to the openhab console, and type list
you should see something like this:
236 │ Active │ 80 │ 4.1.0.202310301434 │ openHAB Add-ons :: Bundles :: SamsungTV Binding
also make sure you have this:
291 │ Active │ 80 │ 4.1.0.M2 │ openHAB Core :: Bundles :: UPnP Transport
If the Binding is not Active, it means you are missing a dependency (like UPNP).
Post your console list here and I’ll take a look.
Ok, first problem is you have two samsungtv
bindings installed. you need to remove one of them.
Ok, enter diag 252
and post what it says.
Ok, as I mentioned many times, you don’t have UPNP transport installed, as it tells you to do in the documentation.
enter
feature:install openhab-transport-upnp
and do list
and diag 252
again.
all working now sorry
