Thank you very much for your fast reply. Yesterday evening did some more testing with the binding and strangely the TV’s where not detected at all. So today, as i have a test instance of openhabian in a debian server, I did some test with it. Installed UPNP Binding and your Samsung Binding and everything works as expected with no issues. Also downloaded an Android APP UPnP Tool, to try and see if the TV’s appear when they are ON and disappear when they are OFF, and from what I see and understand the behavior is as expected.
Here are the output’s of the https://ip:8002/api/v2/ for both TV’s:
{"device":{"FrameTVSupport":"false","GamePadSupport":"true","ImeSyncedSupport":"true","Language":"pt_PT","OS":"Tizen","PowerState":"on","TokenAuthSupport":"true","VoiceSupport":"false","WallScreenRatio":"0","WallService":"false","countryCode":"PT","description":"Samsung DTV RCR","developerIP":"0.0.0.0","developerMode":"0","duid":"uuid:7ada6874-9ec5-433f-9859-1ca9b4843420","firmwareVersion":"Unknown","id":"uuid:7ada6874-9ec5-433f-9859-1ca9b4843420","ip":"192.168.1.162","model":"19_MUSEL_UHD_BASIC","modelName":"UE55RU7105KXXC","name":"[TV] Samsung 7 Series (55)","networkType":"wired","resolution":"3840x2160","smartHubAgreement":"true","type":"Samsung SmartTV","udn":"uuid:7ada6874-9ec5-433f-9859-1ca9b4843420","wifiMac":"d0:d0:03:05:86:f3"},"id":"uuid:7ada6874-9ec5-433f-9859-1ca9b4843420","isSupport":"{\"DMP_DRM_PLAYREADY\":\"false\",\"DMP_DRM_WIDEVINE\":\"false\",\"DMP_available\":\"true\",\"EDEN_available\":\"true\",\"FrameTVSupport\":\"false\",\"ImeSyncedSupport\":\"true\",\"TokenAuthSupport\":\"true\",\"remote_available\":\"true\",\"remote_fourDirections\":\"true\",\"remote_touchPad\":\"true\",\"remote_voiceControl\":\"false\"}\n","name":"[TV] Samsung 7 Series (55)","remote":"1.0","type":"Samsung SmartTV","uri":"https://192.168.1.162:8002/api/v2/","version":"2.0.25"}
{"device":{"FrameTVSupport":"false","GamePadSupport":"true","ImeSyncedSupport":"true","Language":"pt_PT","OS":"Tizen","PowerState":"on","TokenAuthSupport":"true","VoiceSupport":"true","WallScreenRatio":"0","WallService":"false","countryCode":"PT","description":"Samsung DTV RCR","developerIP":"0.0.0.0","developerMode":"0","duid":"uuid:d08d67ff-a2f8-4d5a-9416-f392c59aeb3d","firmwareVersion":"Unknown","id":"uuid:d08d67ff-a2f8-4d5a-9416-f392c59aeb3d","ip":"192.168.1.163","model":"19_MUSEM_UHD","modelName":"UE65RU8005UXXC","name":"[TV] Samsung 8 Series (65)","networkType":"wired","resolution":"3840x2160","smartHubAgreement":"true","type":"Samsung SmartTV","udn":"uuid:d08d67ff-a2f8-4d5a-9416-f392c59aeb3d","wifiMac":"d4:9d:c0:1d:8a:b2"},"id":"uuid:d08d67ff-a2f8-4d5a-9416-f392c59aeb3d","isSupport":"{\"DMP_DRM_PLAYREADY\":\"false\",\"DMP_DRM_WIDEVINE\":\"false\",\"DMP_available\":\"true\",\"EDEN_available\":\"true\",\"FrameTVSupport\":\"false\",\"ImeSyncedSupport\":\"true\",\"TokenAuthSupport\":\"true\",\"remote_available\":\"true\",\"remote_fourDirections\":\"true\",\"remote_touchPad\":\"true\",\"remote_voiceControl\":\"true\"}\n","name":"[TV] Samsung 8 Series (65)","remote":"1.0","type":"Samsung SmartTV","uri":"https://192.168.1.163:8002/api/v2/","version":"2.0.25"}
Both models are from 2019.
Today I am going to do further testing and keep you posted on the results.
Thanks again.
Best regards.
