Thank you for the hints.
- Have you added your TV to the smartthings app?
- Have you created a PAT?
- have you entered this PAT in the binding configuration (and saved it)?
- Yes, TV added to Smartthings app. TV-control by app was tested positive.
- Yes, PAT created with all options enabled via Samsung account
- Yes, PAT entered in binding configuration. I’ve also cleaned the device ID and saved it.
After starting the TV,
-Device ID is not filled up in thing configuration
-I receive following log information (repeating entries were cleaned up by me)
-Searching the log for some output comparable to yours, I could neither find something similar.
(-Additional information: I’ve been using “secure web socket”.)
One funny thing: I’ve checked the my switched-on TV on https://graph-eu01-euwest1.api.smartthings.com/device/show/XXXXXXXXXXXXXXX. There, status was shown as “offline”, but hence there was some notification “some minutes ago”… which does not mach.
2022-02-23 19:03:23.966 [TRACE] [.samsungtv.internal.WakeOnLanUtility] - Sent WOL packet from /192.168.2.62 to /192.168.2.255 64:1c:b0:a1:73:b4
2022-02-23 19:03:24.721 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: remoteDeviceAdded: dialreceiver, http://192.168.2.31:7678/nservice/, upnpUDN=91460a6b-38b6-4be1-9d43-4ce42088292b
2022-02-23 19:03:24.722 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Check and create missing services
2022-02-23 19:03:24.723 [TRACE] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Skipping unknown service: UE75MU6179, dialreceiver (91460a6b-38b6-4be1-9d43-4ce42088292b)
2022-02-23 19:03:24.785 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: remoteDeviceAdded: RemoteControlReceiver, http://192.168.2.31:7676/rcr/, upnpUDN=8860db9b-a273-478f-8b21-88d35219a44f
2022-02-23 19:03:24.786 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Check and create missing services
2022-02-23 19:03:24.787 [TRACE] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Skipping unknown service: UE75MU6179, dialreceiver (91460a6b-38b6-4be1-9d43-4ce42088292b)
2022-02-23 19:03:24.788 [WARN ] [tv.internal.handler.SamsungTvHandler] - Cannot create remote controller service: config is websocket - ignoring UPNP service
2022-02-23 19:03:24.789 [TRACE] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Skipping unknown service: UE75MU6179, RemoteControlReceiver (8860db9b-a273-478f-8b21-88d35219a44f)
2022-02-23 19:03:24.797 [DEBUG] [covery.SamsungTvDiscoveryParticipant] - Retrieved Thing UID for a Samsung TV '[TV] Samsung 6 Series (75)' model 'UE75MU6179' thing with UDN '2430eefa-240d-4f4b-a8fb-ada887551061'
2022-02-23 19:03:24.797 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: remoteDeviceAdded: MediaRenderer, http://192.168.2.31:9197/dmr, upnpUDN=2430eefa-240d-4f4b-a8fb-ada887551061
2022-02-23 19:03:24.798 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Check and create missing services
2022-02-23 19:03:24.799 [DEBUG] [covery.SamsungTvDiscoveryParticipant] - Created a DiscoveryResult for device 'UE75MU6179' with UDN '2430eefa-240d-4f4b-a8fb-ada887551061' and properties: {hostName=192.168.2.31}
2022-02-23 19:03:24.799 [TRACE] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Skipping unknown service: UE75MU6179, dialreceiver (91460a6b-38b6-4be1-9d43-4ce42088292b)
2022-02-23 19:03:24.800 [WARN ] [tv.internal.handler.SamsungTvHandler] - Cannot create remote controller service: config is websocket - ignoring UPNP service
2022-02-23 19:03:24.801 [TRACE] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Skipping unknown service: UE75MU6179, RemoteControlReceiver (8860db9b-a273-478f-8b21-88d35219a44f)
2022-02-23 19:03:24.801 [DEBUG] [nternal.service.MediaRendererService] - 192.168.2.31: Creating a Samsung TV MediaRenderer service: subscription=false
2022-02-23 19:03:24.802 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Started service for: UE75MU6179, MediaRenderer (2430eefa-240d-4f4b-a8fb-ada887551061)
2022-02-23 19:03:24.803 [DEBUG] [rnal.service.RemoteControllerService] - 192.168.2.31: Creating a Samsung TV RemoteController service: is UPNP:false
2022-02-23 19:03:24.830 [DEBUG] [ngtv.internal.protocol.WebSocketBase] - 192.168.2.31: WebSocketRemote connecting to: wss://192.168.2.31:8002/api/v2/channels/samsung.remote.control?name=b3BlbkhBQg==&token=60520187
2022-02-23 19:03:24.831 [DEBUG] [ngtv.internal.protocol.WebSocketBase] - 192.168.2.31: WebSocketArt connecting to: wss://192.168.2.31:8002/api/v2/channels/com.samsung.art-app?name=b3BlbkhBQg==
2022-02-23 19:03:24.836 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Started service for: UE75MU6179, RemoteControlReceiver ()
2022-02-23 19:03:24.837 [DEBUG] [ternal.service.SmartThingsApiService] - 192.168.2.31: Creating a Samsung TV Smartthings Api service
2022-02-23 19:03:24.838 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Started service for: UE75MU6179, SmartthingsApi ()
2022-02-23 19:03:24.848 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: TV is ONLINE
2022-02-23 19:03:24.850 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'samsungtv:tv:2430eefa-240d-4f4b-a8fb-ada887551061' changed from OFFLINE to ONLINE
2022-02-23 19:03:24.858 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TVSamsung6Series75Power' changed from OFF to ON
2022-02-23 19:03:25.065 [INFO ] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: RemoteControllerService found after 2 attempts
2022-02-23 19:03:25.066 [INFO ] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: resend command ON to channel power in 2 seconds...
2022-02-23 19:03:25.066 [INFO ] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: cancelling WOL Job
2022-02-23 19:03:25.734 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: remoteDeviceAdded: ScreenSharing, http://192.168.2.31:9119/screen_sharing, upnpUDN=9ee10438-7588-4660-977e-8c069e411fad
2022-02-23 19:03:25.735 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Check and create missing services
2022-02-23 19:03:25.737 [TRACE] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Skipping unknown service: UE75MU6179, ScreenSharing (9ee10438-7588-4660-977e-8c069e411fad)
2022-02-23 19:03:25.738 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Service rediscovered, clearing caches: UE75MU6179, MediaRenderer (2430eefa-240d-4f4b-a8fb-ada887551061)
2022-02-23 19:03:25.739 [TRACE] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Skipping unknown service: UE75MU6179, dialreceiver (91460a6b-38b6-4be1-9d43-4ce42088292b)
2022-02-23 19:03:25.739 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Service rediscovered, clearing caches: UE75MU6179, RemoteControlReceiver ()
2022-02-23 19:03:25.740 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Service rediscovered, clearing caches: UE75MU6179, SmartthingsApi ()
2022-02-23 19:03:25.992 [TRACE] [ngtv.internal.protocol.WebSocketBase] - 192.168.2.31: WebSocketRemote: onWebSocketText: {"data":{"data":[{"appId":"111299001912","app_type":2,"icon":"/opt/share/webappservice/apps_icon/FirstScreen/111299001912/250x250.png","is_lock":0,"name":"YouTube"},{"appId":"3201512006963","app_type":2,"icon":"/opt/share/webappservice/apps_icon/FirstScreen/3201512006963/250x250.png","is_lock":0,"name":"Plex"},{"appId":"3201412000679","app_type":2,"icon":"/opt/share/webappservice/apps_icon/FirstScreen/3201412000679/250x250.png","is_lock":0,"name":"ARD Mediathek"},{"appId":"3201705012365","app_type":2,"ico
2022-02-23 19:03:26.059 [DEBUG] [l.protocol.RemoteControllerWebSocket] - 192.168.2.31: Installed Apps: 3201612011418 = McAfee Security for TV, 11091000000 = Facebook Watch, 3201909019271 = PrivacyChoices, 3201812017454 = schauinsland-reisen, 3201608010269 = Brandworld, 3201411000562 = Sky Ticket, 11111358501 = Audi, 3201908018988 = RTL+, 3201608010191 = Deezer, 3201903018105 = Samsung SportWorld, 3201803015887 = maxdome, 3201909019084 = CUPRA, 3201601007250 = Google Play Filme, 111199000385 = Digital Concert Hall, 3201502001386 = Joyn, 3201608010221 = ProSieben, 3201412000679 = ARD Mediathek, 3201705012365 = ZDF mediathek, 11101200001 = Netflix, 3201512006785 = Prime Video, 3201511006428 = Rakuten TV, 3201602007756 = Red Bull TV, 111477001080 = Smart IPTV, 111299001432 = Zattoo - TV Streaming App, 3201512006963 = Plex, 111399002250 = DS video, 3201901017640 = Disney+, 3201907018746 = MagentaTV, 111299001912 = YouTube, 3201607009920 = DAZN, 20172100006 = e-Manual, 3201609010528 = Couchplay SpieleCenter, 3201610010814 = Music, 3201703012079 = Eurosport Player, 3201606009684 = Spotify – Musik und Podcasts, 3202112025937 = Getreel Fireplace, org.tizen.browser = Internet, 3201511006303 = DW for Smart TV, 3202011022316 = ARTE, 3201604009179 = SeeColors, 3202103023338 = Aquarium TV
2022-02-23 19:03:27.214 [TRACE] [ngtv.internal.protocol.WebSocketBase] - 192.168.2.31: WebSocketV2: onWebSocketText: {"id":"3201903018105","result":{"id":"3201903018105","name":"Samsung SportWorld","running":false,"version":"2.6.1","visible":false}}
2022-02-23 19:03:28.748 [TRACE] [ngtv.internal.protocol.WebSocketBase] - 192.168.2.31: WebSocketV2: onWebSocketText: {"id":"3201903018105","result":{"id":"3201903018105","name":"Samsung SportWorld","running":false,"version":"2.6.1","visible":false}}
2022-02-23 19:03:34.971 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Received value 'volume':'5' for thing 'samsungtv:tv:2430eefa-240d-4f4b-a8fb-ada887551061'
2022-02-23 19:03:34.984 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Received value 'mute':'OFF' for thing 'samsungtv:tv:2430eefa-240d-4f4b-a8fb-ada887551061'
2022-02-23 19:03:34.987 [TRACE] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Polling Job exception:
at org.openhab.binding.samsungtv.internal.service.SmartThingsApiService.fetchdata(SmartThingsApiService.java:318) ~[?:?]
at org.openhab.binding.samsungtv.internal.service.SmartThingsApiService.handleCommand(SmartThingsApiService.java:382) ~[?:?]
at org.openhab.binding.samsungtv.internal.handler.SamsungTvHandler.lambda$12(SamsungTvHandler.java:558) ~[?:?]
at org.openhab.binding.samsungtv.internal.handler.SamsungTvHandler.lambda$10(SamsungTvHandler.java:558) ~[?:?]
at org.openhab.binding.samsungtv.internal.handler.SamsungTvHandler.poll(SamsungTvHandler.java:556) ~[?:?]
2022-02-23 19:03:36.021 [TRACE] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Polling Job exception:
022-02-23 19:03:37.949 [DEBUG] [l.protocol.RemoteControllerWebSocket] - 192.168.2.31: Installed Apps: 3201612011418 = McAfee Security for TV, 11091000000 = Facebook Watch, 3201909019271 = PrivacyChoices, 3201812017454 = schauinsland-reisen, 3201608010269 = Brandworld, 3201411000562 = Sky Ticket, 11111358501 = Audi, 3201908018988 = RTL+, 3201608010191 = Deezer, 3201903018105 = Samsung SportWorld, 3201803015887 = maxdome, 3201909019084 = CUPRA, 3201601007250 = Google Play Filme, 111199000385 = Digital Concert Hall, 3201502001386 = Joyn, 3201608010221 = ProSieben, 3201412000679 = ARD Mediathek, 3201705012365 = ZDF mediathek, 11101200001 = Netflix, 3201512006785 = Prime Video, 3201511006428 = Rakuten TV, 3201602007756 = Red Bull TV, 111477001080 = Smart IPTV, 111299001432 = Zattoo - TV Streaming App, 3201512006963 = Plex, 111399002250 = DS video, 3201901017640 = Disney+, 3201907018746 = MagentaTV, 111299001912 = YouTube, 3201607009920 = DAZN, 20172100006 = e-Manual, 3201609010528 = Couchplay SpieleCenter, 3201610010814 = Music, 3201703012079 = Eurosport Player, 3201606009684 = Spotify – Musik und Podcasts, 3202112025937 = Getreel Fireplace, org.tizen.browser = Internet, 3201511006303 = DW for Smart TV, 3202011022316 = ARTE, 3201604009179 = SeeColors, 3202103023338 = Aquarium TV
2022-02-23 19:03:38.091 [TRACE] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Polling Job exception:
2022-02-23 19:03:38.103 [TRACE] [ngtv.internal.protocol.WebSocketBase] - 192.168.2.31: WebSocketV2: onWebSocketText: {"id":"3201903018105","result":{"id":"3201903018105","name":"Samsung SportWorld","running":false,"version":"2.6.1","visible":false}}
2022-02-23 19:03:39.123 [TRACE] [tv.internal.handler.SamsungTvHandler] - 192.168.2.31: Polling Job exception:
