Samsung TV detected again and again
I have Samsung QE65Q9FNA TV. It is a model from 2018 and is using SecureWebSocket.
Everything works fine, except that 3 or 4 times a day, it is detected as a new thing “Added new thing ‘samsungtv:tv:’ to inbox.”. Normally I could just ignore, because the thing itself is already file based configured and it is working as expected.
The annoying part is, that every time, when it is detected as a new thing, a new popup occurs on my TV. Either I wait 30 seconds until this popup disappears or I confirm the openhab request every time again.
On my TV in device manager setting, openhab is configured as always accept.
maybe I found the problem.
For some reason the web socket token changed. The token I deployed in my file based configuration was different that the one showing in webui. I changed the configuration to the new token and will observe if the annoying behavior still exists.
that was not the reason. The token is still the same (config file and webui). The samsung binding works, but the tv was detected 9 times today. And every time a popup occurs on my tv, to confirm the openhab request.
2025-02-10 15:32:04.210 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'samsungtv.things'
2025-02-10 16:10:00.102 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'samsungtv:tv:<same-samsung-tv-uuid>' to inbox.
2025-02-10 16:41:30.211 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'samsungtv:tv:<same-samsung-tv-uuid>' to inbox.
2025-02-10 18:29:16.056 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'samsungtv:tv:<same-samsung-tv-uuid>' to inbox.
2025-02-10 20:07:43.157 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'samsungtv:tv:<same-samsung-tv-uuid>' to inbox.
2025-02-10 20:14:58.171 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'samsungtv:tv:<same-samsung-tv-uuid>' to inbox.
2025-02-10 20:20:58.181 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'samsungtv:tv:<same-samsung-tv-uuid>' to inbox.
2025-02-10 20:25:58.186 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'samsungtv:tv:<same-samsung-tv-uuid>' to inbox.
2025-02-10 20:26:58.206 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'samsungtv:tv:<same-samsung-tv-uuid>' to inbox.
