can you provide any example on how to configure samsungtv binding with new new openhab2 syntax ?
For example how can I define item to control volume ?
With the previous version I had the following item:
Rollershutter volume {samsungtv=“UP:Livingroom:KEY_VOLUP, DOWN:Livingroom:KEY_VOLDOWN”}
Now with openhab2 a see this channel:
samsungtv:tv:1bc96ddd_45a2_f109_fffc_8347f4c5735d:volume
How should I define my item do control this chanel ?
Regards
shorty707
(Shorty707)
October 22, 2016, 6:25pm
2
thats my items:
Switch TV1_power "Fernseher" {channel="samsungtv:tv:0r5r4900_0004_1000_94gd_78abhhz43134:power"}
Number TV1_channel "Kanal [%d]" {channel="samsungtv:tv:0r5r4900_0004_1000_94gd_78abhhz43134:channel"}
String TV1_source "Source" {channel="samsungtv:tv:0r5r4900_0004_1000_94gd_78abhhz43134:sourceName"}
Number TV1_volume "Lautstärke [%d]" {channel="samsungtv:tv:0r5r4900_0004_1000_94gd_78abhhz43134:volume"}
Switch TV1_mute "Stumm" {channel="samsungtv:tv:0r5r4900_0004_1000_94gd_78abhhz43134:mute"}
thats the usage on sitemap:
Frame label="TV" {
Switch item=TV1_power icon="television"
Switch item=TV1_source label="" mappings=[TV='TV', HDMI1='HDMI1 - FireTV', HDMI2='HDMI2 - WiiU', HDMI3='HDMI3 - Chrome'] icon="none"
Switch item=TV1_mute icon="soundvolume_mute"
Setpoint item=TV1_volume icon="soundvolume"
Setpoint item=TV1_channel icon="none"
please note my icons are non standard mostly (also ‘none’ is a custom icon)
milty456
(Rich Smith)
November 20, 2016, 6:02am
4
everytime i try this it all works but hdmi 1 in the event log it says two things on one press
2016-11-20 00:58:54.337 [ItemCommandEvent ] - Item ‘LRTV_source’ received command HDMI1
2016-11-20 00:58:54.347 [ItemStateChangedEvent ] - LRTV_source changed from HDMI2 to HDMI1
2016-11-20 00:58:54.593 [ItemCommandEvent ] - Item ‘LRTV_source’ received command HDMI1
2016-11-20 00:58:55.105 [ItemStateChangedEvent ] - LRTV_source changed from HDMI1 to HDMI2
Does it work with the old samsung lcd?
Well, old is relative concept. Binding should support most/some of the C (2010), D (2011), E (2012) and F (2013) models.
It would be great if Samsung TV binding users could give a feedback about used/tested models. See http://docs.openhab.org/addons/bindings/samsungtv/readme.html#supported-things
I have the b650 model, has the LAN socket on the back, could it work?
As far I know, B model doesn’t support upnp or ir remote control emulation, so therefore binding doesn’t work either.
