I just tried to connect my samsung tv with OH2 via files. It just worked fine when I use the binding-feature via PaperUI, but I want to customize the names for using amazon Echo. So I created the following files
samsungtv.thing
Thing samsungtv:tv:livingroom [hostName=“xxx.xxx.xxx.xxx”, port=55000, refreshInterval=1000]
samsungtv.items
Dimmer SamsungTV_Volume "Samsung TV - Lautstärke ändern" {channel="samsungtv:tv:livingroom:volume"}
Switch SamsungTV_Mute "Samsung TV - Stumm" {channel="samsungtv:tv:livingroom:mute"}
String SamsungTV_Source_Name "Samsung TV - Quellename" {channel="samsungtv:tv:livingroom:sourceName"}
Number SamsungTV_Channel "Samsung TV - Kanalnummer" {channel="samsungtv:tv:livingroom:channel"}
String SamsungTV_Program_Name "Samsung TV - Kanalname" {channel="samsungtv:tv:livingroom:channelName"}
String SamsungTV_Program_Title "Samsung TV - Programmtitel" {channel="samsungtv:tv:livingroom:programTitle"}
String SamsungTV_Key_Code "Samsung TV - Funktion aufrufen" {channel="samsungtv:tv:livingroom:keyCode"}
Switch SamsungTV_Power "Samsung TV - Ausschalten" {channel="samsungtv:tv:livingroom:power"}
and integrate it in my existing sitemap
Text label="Samsung TV" icon="video" {
Frame label="Samsung TV Control" {
Switch item=SamsungTV_Key_Code label="Kanal wechseln" icon="text" mappings=[KEY_CHUP="+", KEY_CHDOWN="-"]
Switch item=SamsungTV_Key_Code label="Lautstärke ändern" icon="text" mappings=[KEY_VOLUP="+", KEY_VOLDOWN="-"]
Switch item=SamsungTV_Key_Code label="Stumm" icon="text" mappings=[KEY_MUTE="ON", KEY_MUTE="OFF"]
Switch item=SamsungTV_Power label="Ausschalten"
but the OH2 log said that the connection failed
Any idea?
