I tryied to operate on satel binding on integra 64 through IP ETHM-1 module
config
############################## Satel Binding #########################################
Satel ETHM-1 module hostname or IP.
Leave this commented out for INT-RS module.
satel:host=192.168.100.180
ETHM-1 port to use (optional, defaults to 7094), if host setting is not empty.
INT-RS port to use, if host setting is empty.
satel:port=7090
timeout value for both ETHM-1 and INT-RS (optional, in milliseconds, defaults to 5000)
satel:timeout=10000
refresh value (optional, in milliseconds, defaults to 100000)
satel:refresh=10000
user code for Integra control (optional, if empty binding works in read-only mode)
satel:user_code=xxxx
GUARDIX DLODAX work normaly online access through www work normaly
the comunication is established 4 times evry 1 second
no any item is taken no info even for date time
what I am doing wrong for that ?
There are a logs
2016-05-01 09:39:43.364 [INFO ] [o.o.b.s.i.protocol.Ethm1Module] - Closing connection to ETHM-1 module
2016-05-01 09:39:44.362 [INFO ] [o.o.b.s.i.protocol.Ethm1Module] - Connecting to ETHM-1 module at 192.168.100.180:7090
2016-05-01 09:39:44.377 [INFO ] [o.o.b.s.i.protocol.Ethm1Module] - ETHM-1 module connected successfuly
2016-05-01 09:39:50.364 [INFO ] [o.o.b.s.i.protocol.Ethm1Module] - Closing connection to ETHM-1 module
2016-05-01 09:39:51.367 [INFO ] [o.o.b.s.i.protocol.Ethm1Module] - Connecting to ETHM-1 module at 192.168.100.180:7090
2016-05-01 09:39:51.381 [INFO ] [o.o.b.s.i.protocol.Ethm1Module] - ETHM-1 module connected successfuly
DEBUG
09:56:45.505 [ERROR] [o.o.b.s.i.protocol.SatelModule:458 ] - Send/receive timeout, disconnecting module.
09:56:45.506 [INFO ] [o.o.b.s.i.protocol.Ethm1Module:104 ] - Closing connection to ETHM-1 module
09:56:45.508 [DEBUG] [o.o.b.s.i.protocol.SatelModule:443 ] - Communication thread stopped
09:56:46.506 [DEBUG] [o.o.b.s.i.protocol.SatelModule:441 ] - Communication thread started
09:56:46.507 [INFO ] [o.o.b.s.i.protocol.Ethm1Module:65 ] - Connecting to ETHM-1 module at 192.168.100.180:7090
09:56:46.520 [INFO ] [o.o.b.s.i.protocol.Ethm1Module:70 ] - ETHM-1 module connected successfuly
09:56:46.521 [DEBUG] [o.o.b.s.i.protocol.SatelModule:353 ] - Sending message: Message: command = 7E, payload =
09:56:51.504 [DEBUG] [.b.satel.internal.SatelBinding:76 ] - Module not initialized yet, skipping refresh
09:56:52.506 [ERROR] [o.o.b.s.i.protocol.SatelModule:458 ] - Send/receive timeout, disconnecting module.
09:56:52.507 [INFO ] [o.o.b.s.i.protocol.Ethm1Module:104 ] - Closing connection to ETHM-1 module
09:56:52.508 [DEBUG] [o.o.b.s.i.protocol.SatelModule:443 ] - Communication thread stopped
09:56:53.508 [DEBUG] [o.o.b.s.i.protocol.SatelModule:441 ] - Communication thread started
09:56:53.510 [INFO ] [o.o.b.s.i.protocol.Ethm1Module:65 ] - Connecting to ETHM-1 module at 192.168.100.180:7090
09:56:53.527 [INFO ] [o.o.b.s.i.protocol.Ethm1Module:70 ] - ETHM-1 module connected successfuly
09:56:53.530 [DEBUG] [o.o.b.s.i.protocol.SatelModule:353 ] - Sending message: Message: command = 7E, payload =
09:56:59.509 [ERROR] [o.o.b.s.i.protocol.SatelModule:458 ] - Send/receive timeout, disconnecting module.
09:56:59.510 [INFO ] [o.o.b.s.i.protocol.Ethm1Module:104 ] - Closing connection to ETHM-1 module
09:56:59.511 [DEBUG] [o.o.b.s.i.protocol.SatelModule:443 ] - Communication thread stopped
09:56:59.765 [INFO ] [runtime.busevents :26 ] - Weather_Temp_Min state updated to 10.40
09:57:00.288 [INFO ] [g.openhab.model.script.Weather:53 ] - Temperature evolved of null degrees.
09:57:00.655 [DEBUG] [o.o.b.s.i.protocol.SatelModule:441 ] - Communication thread started
09:57:00.657 [INFO ] [o.o.b.s.i.protocol.Ethm1Module:65 ] - Connecting to ETHM-1 module at 192.168.100.180:7090
09:57:00.672 [INFO ] [o.o.b.s.i.protocol.Ethm1Module:70 ] - ETHM-1 module connected successfuly
09:57:00.674 [DEBUG] [o.o.b.s.i.protocol.SatelModule:353 ] - Sending message: Message: command = 7E, payload =
